Tejasandre
Just got my $10 led for my mag in today. Maybe I'll get to try it tomorrow
Alkalines have a lot higher internal resistance than lithium ion cells such that under heavy current loads they can actually sag lower than lithium ion batteries do. 18650s off the charger are actually about 4.2v under a load that will drop them to 3.7v will likely drop the D cells similarly if not even more. If you shop around you probably won't find any 3D cell lights that can match the runtime and output of a single 18650 light can. An 18650 can be recharged and each time you drain 3 alkaline D cells that costs about $3 or more after about 9 D cells you can pay for a high quality 18650 that will give you hundreds of cycles for fractions of a cent to recharge it each time.Why, exactly, would I only use one 18650 battery when there is room for more? Would that bump the voltage up too high? 3 D-cell batteries = 4.5v and one 18650 battery = 3.7v. Wouldn't using the 18650 be lower voltage and less light from the LED? Sorry if I sound ignorant.........that's okay, because I am when it comes to all of this stuff.
Li-ion has a resting voltage of 4.2v and under load the D cells voltage will drop considerably. So you would likely get better performance from a single 18650.Why, exactly, would I only use one 18650 battery when there is room for more? Would that bump the voltage up too high? 3 D-cell batteries = 4.5v and one 18650 battery = 3.7v. Wouldn't using the 18650 be lower voltage and less light from the LED? Sorry if I sound ignorant.........that's okay, because I am when it comes to all of this stuff.
