I don't think any of us that are not police officers can tell you how much light you need for patrol work but if I was going to stake my behind on a drop-in, it would definitely be a Malkoff. Surefire makes great lights, but their LED drop-in pales in comparison to the Malkoffs. They are built like tanks and are designed to give a constant amount of output for a given amount of time.
You still have options to sort through with Malkoff, mainly light output, run time, light pattern, and tint. The more light a drop-in puts out the shorter its run time (no surprise there). Malkoff drop-ins are available in a "normal" light pattern (similar to an incandescent) or a floodlight pattern that doesn't shine as far (indicated by a 'F' in the name). As for tint, LED lighting looks "cooler" than incandescent, that is, colors will look washed out to a certain degree. Malkoff drop-ins are available in regular or warm tints. The warm tint drop-ins are rated at lower output by testing equipment, but your eyes probably won't register a great difference. If you want the best color rendition, stick with the Malkoff drop-ins with a 'W' in their name.
As others have said, the plastic body of the G2Z cannot dissipate heat as well as an aluminum body light. If you stick with the plastic body, the greatest output drop-in you can use continuously is the M60L (or M60WL for the warm version). Stronger drop-ins will overheat in a few minutes and that can damage the drop-in. If you switch to an aluminum body light (the Z2 is the aluminum equivalent of the G2Z), there are two brighter drop-ins to consider:
M60: noticeably brighter than the M60L and with longer throw (the distance the light will shine). Also available in a warm tint.
M60 MC-E: much brighter than the M60 but with a floodlight pattern (much shorter throw). Also available in a warm tint.
The Malkoff website has detailed information for all their drop-ins. The stronger drop-ins, M60 and M60 MC-E, have warnings regarding use in plastic bodied lights. Finally, don't feel bad if you feel overwhelmed since there is a lot to consider but that also means you have a lot of flexibility available to you.
I hope this helps.
