Cordless Tools 18V Li-Ion Cell Storage Open Voltage
Midnight Oil
Earth
Is it true that, just like any other li-ion batteries, those for cordless tools should not be stored at full charge?
If so, what is the ideal open voltage for an 18V li-ion cell when in storage?
Thanks.
You are correct, full charge speeds the aging process. 30-50% is a good storage SOC. My Ridgid 12v Li-Ion packs recommend the same thing. Assuming you have a 5s pack, OCV for storage should be around 19v (5 cells X 3.8v per cell) Avoid storage in hot or humid environments too!
I used to store my packs at nearly 100% SOC :ohgeez:and they now have the resultant high internal resistance/decreased capacity to prove it. :sigh:
Thanks, David, for moving the thread.
I thought about starting it in this forum at first, but thought it didn't belong here because, though it is about a battery, it's not about flashlights.
Thanks, Adam.
So in essence, each individual li-ion cell should be stored at its nominal open voltage, around 3.7-3.8V. For a li-ion pack, that means the sum of the nominal open voltages of all the cells.
