Greeting everyone,
Recently I opened up my brinkmann lx to check out the batteries. I took the cells out and I discovered what I think is corrosion. I'm not sure what it was.
The positive end of the battery had green goo on it. It was a darkish green color. I just wiped off the goo on the battery. The goo wiped off real easy.
The contact inside the flashlight where the positive end of the battery touched was also covered in this goo.
I finally started cleaning my flashlight today. I couldn't remove the head of the flashlight so I took some tissue paper and a screw driver and cleaned the positive contact inside the flashlight. After the goo came off I noticed the contact had something that looked like rust on it.
Does anyone know what happened to my flashlight? I cleaned off the green goo. But how can I remove the "rust" inside my flashlight. It is a hard to get access to the contact because I can't remove the head of the flashlight. So the only way I've been able to remove the "rust" is by attaching cotton or tissue on the end of a screwdriver and trying to rub the contact clean.
I never let the inside of my flashlight come in contact with moisture so I am not sure if it would be rust.
I use the stock sanyo batteres that were included with the flashlight.
Does anyone know what is going on? The batteries didn't vent or anything and the voltage on them still read 2.93v.
Thanks for any help.
