squaat
So this is my first review like post, so bear with me.
Almost a month ago I stubled across these at my Local Canadian Costco (Willingdon Ave, Burnaby, BC). They cost around 19.99 CAD (last week they were on special for 15.99)
The packaging advertises a 75 Lumen Cree LED, focusable flashlight. Interesting, must have some regulation to do that off two AA's right? A closer inspection showed that it had an Aspheric lens, something that I didn't own yet. So I picked up a pack.
So here's what they look like out of the box (I've removed the crappy clip that it comes with)
Here's a view down the lens (Note there is no reflector at all, just a lens)
Here's the head by itself
Here's it is in candle mode. Note: in the 6 units that I had only a couple could stand on their tailcaps. Perhaps some fiddling with the clicky you could get it to sit flush .
A close up of the LED (any one care to identify the bin?)
The back of the pill module (just screws off the body)
With the circuit board exposed
A Close up of the circuit board. I'm not familiar with circuits, can anyone identify this? I assume the presence of the board means that it's regulated to some extent.
Okay and now for the beam shots... Again bear with me, I only have a crappy point and shoot and I'm new to this.
From Left to right @ approx 1m
LightMate 3W (Flood), LiteMate 3W (Focus), L2D (High)
From Left To right (At a shorter exposure)
I had never seen an aspheric focussed beam shot before, it cracked me up to see the LED chip projected onto the wall. Here's a comparison between the "flood" and focussed beamshots. We'll talk about the "Flood" mode in a bit. Unfortunetly my camera couldn't pick all the detail fo the focussed shot. You can see all the lines in the LED wafer!
Beam pattern
So lets talk some more on the beam pattern. Well to be honest it looks really bad on a wall, there are lots of artifacts that aren't shown in my beam shots. Much of which is a fair way out from the center, miles away from the hot spot (even on flood mode). I assume that this is from the aspheric lens, however i would guess that at least (if not more) 90% of the light is focussed into the hotspots. So in other words in practice you have virtually no spill.
The Focussing feature of the flashlight is bit of a joke really. All you do is loosen and tighten the head. At a certain point you reach the flood mode, which is more like a diffuse mode. The focusing feature doesn't make too much of difference at distances less than a couple metres, but over a long distance, say 10+ meters, it definitely starts to show, but this is more due to the tightness of the focussed mode. However because there is no spill and the flood isn't really that floody, it definitely limits the practicality of flashlight.
The Fully focussed mode is so focussed that you can see the outline of the Cree LED, lines in the wafer and all! This makes the Lightmate 3W a really good budget thrower. It far out throws my L2D (even on turbo) and throws just as far as my modded MAG (TerraLUX MiniStar5 TLE-6EX SSC P4 running on 6AA) which is close on throw to a TK20. So yeah the focussed mode is pretty tight, and you can easily see the beam projecting up into the night sky. And it looks awesome in the fog!
Still it feels a tad strange waving a funny Square(ish) shaped beam around.
Build Quality
Not the greatest. I'm no finishing expert, but it's nothing like the HA III on my Fenix lights, and not as good as the HA II on my mag. Threads can be rough depending on the sample, and the o-rings are sometimes loose. However the build is quite heavy set, especially the head.
The focus mode varies from unit to unit, but most (and I've bought 6 as gifts for non flashaholic friends) are IMHO too loose when in focussed mode. While I don't think the head would fall off, it seems a tad wobbly.
I've also found that this flashlight is very easy to disasseble. Everything is screwed together and with minimal effort it comes apart. So far I've taken the LED module off (see pics) and i've been able to remove the lens as well. (which is plastic). Perhaps this could be a good host for mods...
Runtime and regulation
Unfortunately I have no time or way to measure output, runtime so I can't really make any real sound comments here. Sorry. But for what it's worth I compared my orig unit to the ones I bought last week (which was used occasionally for a month and is still on it's orig alkaline cells) to my recent purchases and can say that they seem equally as bright.
Conclusion
Well the flashlight impressed my non-flashaholic friends, and many have shown interest in it. So for less that $10 each they are awesome for gifts.
I've added one to my collection, but it was for completeness not because it was a must have.... okay I admit I get a kick out of the tight focus and like that it can be kinda used as a star pointer
However over time I've come to appreciate a decent spill, this flashlight has no spill and the focus mode is not diffuse enough to compensate. So if you are after a cheap thrower, then this is your ticket, if you want to get friends and family off their cheap incands then this is also your ticket. I know I've given quite a few away.
But in the end you get what you pay for, and this is a decent sub $10 thrower.
Beam pattern
Build Quality
Conclusion
