CPFReviews.com: LiteFlux LF2 SSC P4 & LF2 Cree XR-E ... Comparisons Runtimes..
ViReN
CPFReviews.com
LiteFlux LF2 SSC P4 & LiteFlux LF2 Cree XR-E
provided for review by http://www.liteflux.com/
General Description:
LiteFlux LF2 SSC P4 is a small sized programmable LED flashlight. This light is one of the 4 models of LiteFlux Beacon Serials flashlights Series from LiteFlux. LF2 SSC P4 supports multiple types of AAA Batteries ranging from Alkaline AAA battery to rechargeable 10440 Li-Ion battery. LiteFlux LF2 is built from aircraft grade aluminium. It has hard anodizing type 3 coating offering good environmental protection, corrosion resistance and durability. LF2 has O-Ring Seals at different locations such as between bezel and lens and between battery tube bezel which provide a good water resistance. LiteFlux LF2 SSC P4 has a specially designed unique 2 stage twist switch. With Seoul Semiconductor P4 power LED as solid state light source, LiteFlux LF2 is one of the brightest lights in its category especially when powered by 10440 Li-Ion battery. LiteFlux LF2 SSC P4 has advanced drive circuit, with programmable micro controller offering great flexibility in operation and programming options. LiteFlux LF2 ships in beautifully packaged wooden gift box.
Light Features:
  • Unique 2 stage twist switch
  • Micro controller controlled with extensive programming options
  • SSC P4 LED
  • AR Coated glass lens
  • Supports multiple AAA Battery types
  • Can stand on tail, includes diffuser for excellent lantern type operation
More....
Jump To: Pictures - Beam Shots - Candle Shots - Extreme Closeup Pictures
Update 2: 12/10/2007
Runtime Update .. Please Press "Ctrl + F5" on keyboard to get the updated Runtime chart
Alkaline 1: I have used an OLD USED AAA Battery (taken out from DX's 30 mW Laser) to do this runtime as I didn't have any new AAA cells. Runtime on depleted alkaline is about 36 minutes till 50%
NiMH: The La Crosse 700 mAH battery was charged on the La Crosse BC900, given rest for 2 hours and then put up on Extreme Tech Hyper Efficient Very Special Runtime Rig :duh2:. Runtime on NiMH is about 51 minutes till 50%
Alkaline 2: I have used New Energizer AAA Max ..Runtime is about 25 minutes till 50%, sounds kinda low, but then again current draw is about 600 mA.
Alkaline 2 Re: I have used Same Energizer AAA Max from the above test after about 2 hours of rest ..Runtime is about 15 minutes till 50%. Notice that the light runs in regulation for all battery types.
I plan to do the runtime again from the Alkaline 2 Re stage...I have just noticed that light is still bright after rest of 10 minutes. This time, I would like to give it rest for 8 hours. Lets see how far the AAA cell recovers.
Update 3: 12/10/2007
Alkaline 2 Re Re: I have used Same Energizer AAA Max from the above test after about 8 hours of rest ..Runtime is about 14 minutes till 50%. Again you will see that the light runs in regulation even for highly depleted battery. what this means that under practical conditions, you should be able to get atleast an hour or so of combined runtime with Alkaline AAA Battery.
It should be noted that during practical use, it would be on exceptional occasions that you would be using light for hours at a stretch. And if Alkaline battery is given time to recover, it would be safe to say that combined runtime would last more than an hour or so with decent regulation. The above runtime chart just proves the same.
Update 4: 16/10/2007
Just Posted review of LiteFlux LF2 Cree XR-E Version, a comparison and differences between the SSC P4 counterpart have been highlighted.
Runtime for Cree XR-E version of LiteFlux LF2 is very similar.
Jump To: Top - Light Info - Pictures - Beam Shots - Candle Shots - Extreme Closeup Pictures - Runtime
Re: CPFReviews.com: LiteFlux LF2 SSC P4
Awsome review ViRen! Man that is professional looking and your pictures look fantastic. Your pictures alone make one want to buy this light. Keep up the great work!
Viren,
I have been keeping an eye on the LF2 for the last few months and really enjoyed your review. Heck, I was going to order one but they want me to register or something. Instant kill on the buying urge!
My plan was buying the Cree version as I prefer their durability over the SSC LEDs. Is LiteFlux the only seller of the LF2? Great review!
Thanks BentHeadTX, I am doing Runtimes and Cree LF2 Review. Hope to finish by this weekend :) :thumbsup:
Thanks for the review. I'm also looking forward to the runtime tests.
Hey BentHeadTX, I also prefer the Cree. I have had mine for a while now and still think it is about the best "Bang for your buck" AAA light around. I Don't remember having to do any register when I bought it from LED Cool.
I'm like you, if I have to register at a site to buy something I find somewhere else to get it.
LF2 SSC has been dutifully performing as my keychain light for many months. Love the darn thing. Bought another to give as a gift, and bough the Cree ver to try out. But it is the SSC version that fit my needs better as a keychain light.
Excellent review again, ViRen! I've tried the LF2 Cree but have not had a chance to check out the SSC version. Since you have both, any way to do a little comparison for us when you have time? I'm not sure which one is more suitable for me.
I know the SSC is more floodier and the Cree with more throw but to what degree of each other? I'm also interested in numbers and runtimes. Keep up the good work! Thanks!
Re: CPFReviews.com: LiteFlux LF2 SSC P4... Runtime Added
Update 1: 11/10/2007
Runtime is just in :D
Alkaline: I have used an OLD USED AAA Battery (taken out from DX's 30 mW Laser) to do this runtime as I didn't have any new AAA cells. Just coming back from the market and got Energizer AAA Max Alkaline. Will be doing the Fresh Alkaline runtimes tomorrow and will update accordingly.
I haven't put these runtimes on site, will be updating tomorrow... with the fresh alkaline results
Thanks supes
I am going to post the comparative review of Cree LF2 shortly...
here's some teasers :D
Give me time till this weekend and it should be up along with runtime and the Light Info. Cree LF2 is more throw and is having a deeper reflector...
Dang your fast! Take your time, mate! Enjoy the weekend! :thumbsup:
I just remembered really liking the LF2 Cree and its output, and what a killer on Li-Ions.
need to have a 10440 cell in there to make the light really shine... Wouldn't run mine any other way...
Will it be safe to run on 10440 cell on Max for long periods of time?...I have put up the 10440 cell and it gets real hot in a couple of minutes... but it's verrrrry bright :) The total output with fresh NiMH is 275 ... and with 10440 cell... it is 550 :faint:
Also, when run on low, the light stays cool :) which again a good feature. Thujone, now I see an advantage of using 10440.. it seems logical... like most of time we would be using low... but if need be, switch to high gear and get about 60 Lumens at disposal from that small light ... :thumbsup:
See Update in latest post and the first post.
Update 3: 12/10/2007 (Press "Ctrl+F5" to refresh the page with latest runtime)
Alkaline 2 Re Re: I have used Same Energizer AAA Max from the above test after about 8 hours of rest ..Runtime is about 14 minutes till 50%. Again you will see that the light runs in regulation even for highly depleted battery. What this means that under practical conditions, you should be able to get atleast an hour or so of combined runtime with Alkaline AAA Battery.
What level is used for your run time tests? Is it 100%, or one of the pre-programmed modes? Also, did you have any of the protections enabled?
