ViReN
LRI Photon Rex Micro Light
provided for review by LRI
General Description:
A few pictures
I will add more information as I progress...
LRI Photon Rex Micro Light is next generation rechargeable Lithium Ion battery based LED flashlight with a row of 4 LED's inline array. The four premium binned LED's make Rex extremely bright for its size. Photon Rex is similar to Photon Freedom and Photon X-Light Micro in some ways; in fact Rex is an enhancement to previous product lineup and shares Freedom UI features. What's unique about the Photon Rex is its ability to recharge from commonly available batteries. For instance a standard AA alkaline battery or a D size alkaline battery will be sufficient to recharge Photon Rex. This is mainly because Photon Rex has special inbuilt recharging circuitry. Build quality wise, the ABS plastic body offers great wear and tear resistance. LED's are protected by shields on either side of inline array. LRI Photon Rex uses premium Nichia GS LED's.The switch is made of glow in the dark soft touch rubber material. The entire LED array works in conjunction with Freedom UI features that include variable brightness, different signal modes and SOS mode. The rechargeable battery is capable of charging up to 500 times, which means if you charge your Photon Rex Micro Light twice a week, you would not need a service replacement for more than 4 years! This is just incredible. Imagine using a flashlight without replacing batteries for 4 years. Thanks to the high efficiency rechargeable Li-Ion battery. That's the LRI's commitment to environment. Future accessories will include a solar panel recharging device as well as a USB port re-charger.
More...A few pictures
