CroMAGnet
Got the bug to try a super simple mod that even I could do, ehem, with JimH's help. I went over to get the details on how to mod a Mag 2C using three CR123 Lithium 3v batteries. But what did I find when I got there? THE USL!!!!!
Holy cow is that thing bright especially at close range!!!!
Jim has a cutdown piece of clear vinyl tubing, much like you see used for aquarium air pumps but a lot larger. We used three different bulbs and measured the current draw under load and they all came to around 1.8A draw. We couldn't measure the Voltage under load, so if anyone wants to add this info please do
Here are the bulbs.
Carley CL1499 6V
Carley CL612 6V Krypton
Reflectalite.com GH24 6V 10W
I'm waiting for darkness to fall so I can measure the LUX readings to find out which bulb has a brighter hotspot if any and I will also take some beamshot pics with my new manual digital camera.
I'm still not sure of the efficacy of each bulb and which one will have the longest runtime so please share your ideas and data.
PS late last night I was able to measure one of the bulbs at 19,000 LUX !!!! more to come
Quote from an old CPF thread on the CL-1499
Here is what is on Reflectalite's page GH24 Halogen 6V 1.7A 10W 201-Lumens for $6.24 each
Here are the bulbs.
Carley CL1499 6V
Here's some data I found on the CL-612 Krypton 6V 1.7A 10.2W fil.res. 3.53 ohm and 182-LumensCL-1499 (I don't think it is on their website)
T-1 1/2, xenon, 7.2 volts (optimized to be operated with 3 lithium batteries), 1.84 amps, 30.7 candle power (avg.), 3450× kelvin @ 7.2 volts (3500× kelvin @ 7.8 volts), 15 life hours @ 7.2 volts (10 hrs @ 7.8 volts)
I got a few from Carley last year and they have been quite robust performers (no failures yet after many sets of batteries). At 3x123, they seem to be a smidge brighter and whiter than CA808's on 4x123, and because they are the smaller T1.5 size (versus the T2.5 CA808), they can focus to a tighter spot. The smaller size should also cause less "thermal distress" to the stock reflector (I think in theory the Mag reflector should be able to handle this wattage, but I did have some slight reflector discoloration occur when running a CA808 that was potted slightly off-center). And you should be able to run these off of 6 nimh AAs quite well, although I haven't gotten off my lazy butt to try this yet.
