dealgrabber2002
If my car alarm uses 1 CR2016, can I use CR2032 instead? what is the different? Is it the size? Same voltage? CR2032 have better capacity?
It might, depends on the cavity. I used to have an old sony video camera that used a 2016 as clock backup; when that died I mistakenly bought a 2032, but since I didn't want to go to the store again I just pushed it in stronger than usual and it stuck there, a bit askew, but it worked.It won't fit in a cavity meant for a CR2016.
"If at first it doesn't fit, use a bigger hammer."
