Cree ScreenMaster 5mm oval LED review
JohnR66
SW Ohio
These LEDs are designed for full color RGB digital displays according to Cree, although I can come up with more uses! They come in red, green, blue and amber. Cree claims, "Best matched and brightest 5-mm oval RGB LED series in the industry." Also available in a 4mm version.
The oval shape gives an elongated beam with an angle of 40 x 100 Deg. The epoxy encapsulant is the same color as the emitted light and is diffused a bit (you can still see the lead frame inside). As you can see, they are a lot smaller than an ordinary 5mm LED and has no flange, thus can be packed tighter on the PC board.
I have tested only the red so far. Good news as these are using Cree's newer high performance dies. The die cup is the anode on the red and probably the amber.
The beam shot shows a nice smooth oval beam (not quite symmetrical due to camera angle). To my eyes, there is more of a horizontal band of light than the camera shows for some reason.
I could see an array of these used as a bike tail light without the need for lenses to spread the beam horizontally.
I probably won't be fade testing them given that I tested Cree White 5mm LEDs and found them to have an excellent lifetime. I hope to get the other colors when I get more free cash to spend.:broke:
These would be great for their intended use, but as you said, I bet the cyclists on this board would LOVE these LEDs. All you have to do is solder a simple array of LEDs with resistors. No optics, no beefy heatsinks.
