Red emitter enhanced White LED light
JoakimFlorence
Active-Grow-LED-Grow-Lights-Sun-White-Pro-Full-Spectrum_14f03990-cce4-4b7b-bdee-d06f08c11c42_540x.jpg
With normal white LEDs, which just use a blue emitter in combination with a phosphor, there is an inherent trade-off between CRI and light efficiency.
How much is this trade-off, exactly?
70 CRI is typically around 9 to 12% more lumen efficient than 80 CRI, all else being equal.
Going from 80 to 90 CRI, the total lumen output will drop by about 10 to 15%.
Going from 90 to 95 CRI, the lumen output will drop by 15 to 18%.
reference source: https://www.clearlighting.com/why-high-cri-led-strips-dont-provide-more-lumens/
Why does higher CRI result in a drop in lumen efficiency?
Mainly it has to do with generating red wavelengths of light. Generating red light from a phosphor is not very efficient. This is especially the case for deeper (longer) wavelengths of red light, when we are talking about getting more into the pure "ruby" red, rather than just orange-red.
This is due to two reasons. The eye has a lower sensitivity to deeper longer wavelengths. 630nm is more than twice as bright as 650nm.
The way a typical LED phosphor works, it generates a broad band of wavelengths. To be able to produce a peak of red wavelengths mainly around 640 or 650, the phosphor would also be converting a lot of the input energy to near-infrared light, which is invisible to the eye.
There is one last reason as well. Blue light contains more energy than red light (given an equal number of photons). This means that creating blue light and converting it to red light results in an inherent efficiency loss. For 450nm to 650nm, it would be a loss of 31%.
These efficiency losses could be mitigated if one just used a red LED emitter to produce the red light for the white LED.
This might sound very simple, but it does result in some complications.
Firstly, the light has to be well mixed. Secondly, the light has to be precisely color balanced. This can be difficult because the human eye is very sensitive to slight color tint deviations from "pure white", also because red LED emitters lose a small but significant amount of lumen output as they heat up, more than the blue LED emitter does. A large part of the reason for that is that increasing temperature results in a small shift to slightly longer wavelengths, and in the red area of the spectrum, eye sensitivity very quickly begins dropping off as the wavelength increases. This tends to result in throwing off the color tint balance.
Most white LEDs use a mix of two phosphors. (Actually it's most commonly the same type of phosphor, but the doping concentration is a little different resulting in a shift of wavelength output) There is a "red" phosphor and a "green" phosphor. (Actually that's not really the most accurate, it's usually more like a "mostly yellow-orange phosphor" and a "mostly yellow-green phosphor") Used together, they help to give a flatter and more extended distribution of wavelengths across the spectrum, ideally from red to green. But often the phosphor does not do the best job of that and the total light output from the phosphor tends to be more "yellowish" in its distribution. (This is why lower quality LEDs often had a reputation of producing "faux white" light, that somehow didn't seem quite right)
When trying to make white light by combining a red LED emitter together with a blue emitter with an adjusted phosphor composition, you can't just use a "green" phosphor. It is not as simple as that. That would result in an imbalance and result in lower CRI and poorer color rendering ability. There are two possible approaches. You could use a very yellowish-green phosphor and then combine that with a very orange-red LED wavelength, such as 510-115nm. Or you should use both red and green phosphor, but just use less of the red phosphor. In this case you could (and should) select a "red phosphor" that is more yellow-orange, since the LED emitter would be providing the deeper red wavelengths.
What exact wavelength of red LED should one pick?
This can depend on several factors, such as efficiency, desired CRI and red color rendering ability, and what the color temperature of the light will be. (Also, the consideration of simplicity and cost may make choice of just one red wavelength preferable to two different red wavelengths)
For 2700K or 3000K, the best red wavelength is 650nm. When going above 3650 to 3800K, or let's just say 4000K, it is better to go with 630-635nm. If you are aiming for the very maximum possible lumen efficiency, then 620nm will be the best choice. If using two different red wavelengths, then 650nm and 610-620nm would be the most optimal.
(Also, if adding a green LED emitter, 520nm is the most optimal)
What about using 660nm? Will that give better red color rendering?
Red colors will indeed be more saturated under 660nm, but it will be in a way that's beyond how red colors look under any natural light. Also consider that 660nm has less than half the lumen efficiency of 650nm. Using 660nm is really unnecessary and not optimal. 650nm is completely acceptable and will still make reds appear with the same saturation as they do under incandescent or natural sunlight.
What about using the red LED to generate most of the red light in the spectrum? Why does one still need to rely on the phosphor to produce red light?
The problem with relying on red LEDs to produce most of the red light is that it will result in skin tones looking far too pinkish. Not only too pinkish but also paradoxically too pale and not very warm. Why? Because when using deeper redder wavelengths, there is only so much that can be added before it starts throwing off the color balance of the light. To have a warm and healthy "tanned" skin tone appearance, you need very orange-red light, which is somewhere in the range of around 505 to 515 (or an added red emitter of 515-520nm, when combined with phosphor).
What percentage should the red emitter light be out of the total white light?
The red emitter should only be around 5 to 12% of the total light in the spectrum, and probably around 6 to 8%.
What CRI could I expect to achieve from this approach?
Adding a red LED emitter to an 80-85 CRI type phosphor composition could easily result in 94 CRI.
If a better phosphor composition is used, 95 or even 96 CRI.
A single greenish-yellow phosphor combined with 510-515nm orange-red can achieve 93 CRI.
What about 97 or 98 CRI ? Is that possible?
For the 2700 to 2900K range, it is possible, but you would need to be using an excellent phosphor composition.
Most probably there would need to be two separate wavelength red emitters in that case.
Currently, 97 or 98 CRI is usually regarded as impractical due to the significant efficiency loss, but using separate LED emitters it could allow that to theoretically be just as efficient as regular LEDs.
With all-phosphor LEDs, there is a very significant loss in efficiency going from 95 to 98 CRI.
If we are talking about 4000K or 5000K, I think it would top out at 96 CRI, as the maximum theoretically possible. To be able to exceed that, we would need to talk about doing some other things.
A couple points:
First off, mixing red LEDs with low-CRI white or off-white to get good color rendering is not a new idea. The old L-prize lamps used this approach back in 2012, and Cree had some downlight retrofit kits that also used this approach a couple years before the L-prize lamps.
Second, the flux hit for 90+ CRI is down to about 5% referenced to 80 CRI with the latest KSF-based phosphors. I haven't checked the 95+ CRI options recently, but I expect that they are also seeing similar phosphor improvements.
It is true that with the development of better phosphors, the lumen efficiency cost of being able to achieve better CRI has decreased somewhat.
When added to a 3000K 90 CRI LED phosphor blend, KSF can increase the lumen efficiency by 18%.
Under 450nm (blue light excitation), the quantum efficiency of KSF is 54% (that is 54% of the blue photons will be converted to red photons).
It probably does not matter, but for anyone who was wondering, "KSF" phosphor stands for K2SiF6: Mn4+ (potassium fluorosilicate, dopped with "manganese tetrafluoride" in the form K2MnF6 ). It is a "ceramic phosphor", with two absorption bands at 320-380 nm and 400-500 nm, and emission peaks with five sharp peaks in the 600-650nm range; the tallest peak is at 630-631nm (orange-red), the two second tallest peaks are at 635 and 608nm. (There are two additional tiny peaks at 597 and 648 which are much less significant)
The doping seems to work best at around 1% (by weight) Mn concentration.
One of the disadvantages to this phosphor is it is sensitive to moisture and has to be kept dry (away from humidity) before being mixed together in the phosphor composition with the silicone binder. This can make the manufacturing process a little more difficult and complicated.
(reference sources: https://www.osti.gov/servlets/purl/1638691 , https://www.ncbi.nlm.nih.gov/pmc/articles/PMC10788833/ )
This is just a guess based on instinct, but based on the emission peaks of KSF phosphor, it is probably only really suitable for achieving 94 or 95 CRI. For higher CRI than that, they might have to go with a different red phosphor.
dicuno-90cri-2700k-jpg.63893
I suspect the biggest reason enhancement with separate red LED emitters have not become a common design has to do with added complexity, mainly when it comes to color consistency and color shift.
Unless very stringent quality measures are undertaken, not all LED emitters in a mass production are going to put out precisely the same peak wavelength or brightness. With the normal white LED approach, this is not a problem, but when there is a separate red emitter, it very much becomes a problem, because it can lead to a color tint imbalance.
As the emitters heat up during operation, there is some wavelength shift, which can affect precise color balance, especially when red LED emitters are being used. (Human eye sensitivity to red wavelengths rapidly falls off as the wavelength increases, whereas at more orange-red wavelengths, any increase in wavelength can rapidly shift the red-green color balance further towards red)
There are ways this problem could be addressed, but they all lead to added complexity and cost, and thus are not felt worth it.
Another reason why many manufacturers may not think it is worth it is they consider it does not make sense to be adding this separate LED system when it may only be putting out 6 to 10 percent of the light. Yes, there is a very significant drop in total overall efficiency when not using a red LED emitter, but that efficiency is not felt worth the added design complexity. And moderately high CRI (like 90-92 CRI) can still be rather efficient without needing a separate red emitter. Very few of the standard most commonly used LED lighting products are higher than 92 CRI. And most products that do offer higher CRI than that are spotlights, where the light from a separate red emitter would not mix evenly very well, and usually these lamps are small in size, making any added complexity more of a challenge. So even though there might theoretically be a practical place for red emitters, it's just not in the great majority of LED lights being sold.
From what I've seen, it seems the only place manufacturers are willing to use the design of separate red emitters is in corporate commercial lighting, where the lights will be on most of the time, and where energy efficiency and energy cost savings are likely to be strongly considered, but where a little higher CRI (like 93 to 94) is desirable. (Going from 90 to 93 CRI really does add a lot of feel of "warmth" to the light, and color rendering) But because the market for this is so small, it's difficult to reach big enough scales of production for these products to bring costs down. (Though even at 5 times the cost of comparable LED alternatives, they can still be worthwhile in energy saving costs in the long run)
Just do what the plant tubes do
Put a few in each series string.
I did this in my custom ceiling fixture.
A few deep red and a few orangered with 32 nichia 219c 4000k
I did a little casual experimentation.
I have some portable lamps with both a white LED and red LED setting, so I used two of these portable lamps to go around viewing things under the combined white plus red light.
The white LED I would roughly estimate to be maybe around 72 or 73 CRI. The red LED might be around 635nm.
The combined white plus red light seemed to give an appearance correlating to what I would estimate to be around 88 to 89 CRI.
Both the white and red settings use the same amount of current, though the voltage may be different. But I think the white LEDs might be more efficient than the red, so there is much less red light by comparison.
So adding red does seem to be able to increase the CRI by about 16 points, in this situation.
This was far from perfect and very casual, of course, and without any attempt to try to achieve optimal mixing ratios.
(And this is judging based on color appearances and plenty of instinct, knowing how things appear under many other different LED lights)
And obviously when you are simply mixing white and red light, the resulting white light becomes just a little pink tinted.
