Sorry for the brief post (I usually cannot help to discuss further), but didn't Lumileds have a Green Rebel 0080 out for quite a while. This means that this green Rebel should produce a minimum of 80lm @ 350mA. I probably wouldn't have noticed if I had not bought the green Rebel 0080 recently. This new "70% brighter" green by Cree produces 87.5lm. Cree says 70% brighter, but isn't that because their old green XLamp7090XR emitter only emitted 52lm @ 350mA or the green XR-E emitted 67.2lm @ 350mA? 87.5lm is about 70% better than the 52lm green. Compared to the best green out there, Cree's new green isn't 70% brighter. This makes Cree sound like they are doing well, I suppose.
-Tony
Also, for RGB lighting a green emitter of around 545 nm would be ideal.
How do you reach that conclusion?
As I figure it, the ideal RGB triplet is one whose triangle on the CIE diagram covers the greatest area and/or most closely fits to the edges of the diagram. The frequency at the top which minimizes the leftovers on each side is around 520nm. 545nm is down the right side and would leave a large lobe of out-of-gamut colors in the pure green through cyan area. Perhaps you meant 525nm, which is pretty close and a common color?
My current choices would be 650nm-520nm-455nm for RGB.
The tri-color optimizations I've looked at give the best balance of color rendering and emitted efficiency by choosing a green emitter in the 545 nm area. Also, the red emitter would be in the 605 to 615 nm area. Granted, these results are not exactly intuitive, but they are what they are. You can get a CRI in the low 80s and an emitted efficiency around 400 lm/W. For don't gain that much higher color rendering, if any, by going with a 525 nm emitter, but you loose quite a bit in efficiency. For CRI much greater than about 80 you're better off with four or five emitters anyway. See here.How do you reach that conclusion?
PhantomPhoton,
The metric of Lumens is a measure of the radiant output, the Watts of light, multiplied by the sensitivity of the human eye at that wavelength. That means that one lumen of red appears as bright as one lumen of green. Its just that the lumen of green requires less radiant wattage. Think of it like density. It's like wattage is volume and lumens is weight. Which weighs more, a pound of feathers or a pound of bricks?
As the thread is about white light, we are not concerned with Color Gamut, but efficiency, hence the choice of wavelength.
Semiman
