Current draw in series?
Splunk_Au
Melbourne, Australia
So with thte current divider rule, current drops across components connected in series. Does this also apply to batteries?
If there are 2 AA batteries wired in series and the total current draw is 2A, does this mean that the current draw is 1A per battery?
Nope, exactly the opposite. If you have two batteries in series, and the total current is 2 Amps, then each battery has to give 2 Amps. If you had two batteries in parallel, then each battery would give 1 Amp. Maybe you're thinking about how power gets split up.
2 x 1.5v batteries @ 2amps = 3v x 2A = 6 watts total. (P=IV)
each battery is giving: 1.5v x 2 amps = 3 watts each. (3 watts x 2 batteries)
Power would still add up using addition in parallel circuits.(for each battery)
2 x 1.5v batteries in parallel, total current is 2A = 1.5v x 2A = 3 watts total.
each battery is giving 1.5v x 1 amp = 1.5 watts each. (1.5 watts x 2 batteries)
Hope this helps!
:grin2:
It's perhaps a little better still to let each battery continue to give 2 A even when in parallel?
Then you would have 1.5 V x 4 A total = 6 W, and 3 W per battery as with the series case.
Just think about how a series circuit is wired, there is only one path for the current to take so the current in each part of the circuit must be the same.
Norm
