Current Drawn From single AA 1.2 V NiMH
Sanyo.Eneloop
India
my question is that a bulb is rated 2.4Volt and .5A(500mA)
if i connect 1 AA NiMH cell and i try to glow that bulb will that bulb draw 500mA per hour on 1.2Volts ???????????????
Re: Current Draw From NiMH
Well, do not have any 2.4 volt incan bulbs, but I just now undervolted my Streamlight TL3 with 6 volts, and it lit up, pulling 1.1 amps from the two CR123's (used a SF dummy CR123). With 3 CR123's it pulls 1.25 amps.
Your 2.4 volt example bulb is most likely set up to run with two 1.5 volt alkaline cells, and would not function with one 1.2 volt cell, and draw from battery would be minimal, if any. Typically for incans when voltage drops so does current draw from the cell. I was surprised that my TL3 is running fairly bright with two CR123's, and I will take a bounce with lightmeter check soon.
You have no incan lights to work with and no DMM?
Bill
Actually a 2.4 V bulb will light quite brightly with a 1.2 V supply. Not full brightness of course, but visibly lit up. Incandescent bulbs have the property that the filament resistance decreases with lower voltage and increases with higher voltage, so that they try to regulate the current.
Your result with the TL3 is not therefore that surprising. At two thirds of the normal voltage you get more than two thirds of the normal current due to the current regulating behavior.
guys 2.4V bulb is glowing nicely with 1 AA NiMH but i wanna know on single NiMH cell bulb will draw 500mA @1.2V or 250mA @ 1.2V?????????
Ohm's law is : V = R x I
2.4V for 0.5A means that the DC resistance of your bulb is 4.8 ohm.
if R was constant, under 1.2V, it would draw 1.2/4.8 = 0.25A, which is 1/4 of the power.
But at this power, the filament will be cooler, and then have a lower DCR, drawing more current. How much it exactly draw will depend on the type of filament, and also on the capacity of you battery to provide such current. So I would say with an NIMH battery and average bulb you can expect it to draw about 0.3-0.4A. This can be mesured easily to have the true value.
One last point is that at 1/2 it's voltage, the light bulb may be very less efficient.
HTH,
John.
i'm waiting for my answer
Sorry to keep you waiting.
From your other posts, I see you have a meter - so why don't you measure the current, and let us know how much it draws? ;)
Cheers
Cheers
from that digital multimeter i can measure an cell amps which is showing 5.5 A(checked for 2 seconds max!!)
but how can i measure bulb Amps is consuming per second through multimeter??????
on bulb its printed that 2.4V and .5A if i use one cell to lit bulb will that bulb consume .5A or .25A??????????
I'm still not convinced
I've conducted this test on a 5.4V bulb running it by ENELOOPS
I lit that 5.4V bulb through 2.4V(2x1.2 eneloops) then multimeter showed me .3A(300mA) current drawn by bulb, after that the bulb is on for continuous 6hours and 45min!!! till .95 V
by drawing 300mAH by bulb it means 5mAH per minute and bulb lit for total 405 mins X 5mA =2025mA
and rated capacity capacity of ENELOOP IS 2000mAH !!!
ENELOOP IS GROUNDSHAKING NiMH!!
Note that mAh is mA x h.
So 300 mA for 6h45m gives:
300 mA x 6.75 h = 2025 mAh
You arrived at the right answer, but your working was incorrect. The above calculation shows the correct way to do it.
to Sanyo.Eneloop --
Welcome to CandlePowerForums !
:welcome:
Hey, do you realize . . . .
You and I both have Battery Manufacturers
as our CPF UserNames.
:whistle:
_
Dude I'm from INDIA and there is no maha charger and la crosse available in Indian market, but I've told my brother in Canada to buy it and parcel it to me.
There is a Location field in your user profile (see top right corner of posts). It is good to fill it in so people can know what might or might not be available where you are.
...by drawing 300mAH by bulb it means 5mAH per minute
No, your bulb was drawing 300mA (300 milli-Amps), not 300mAH (300 milli-Amp Hours).
milli-Amps is a measure of current, and already has a time component. One Amp (1000 mA) is equivalent to a flow of 6.242 × 10^18 electrons per second.
Amp-Hours and milli-Amp-Hours are measures of how long a battery can sustain a particular current draw under certain conditions.
