Custom Pelican M6
pmkringiv
I have a a Standard Pelican m6 Inc light. I want to convert it to LED. As bright as possible to be used for a personal defense light. Any ideas Please help:thinking:
Does your light use the screw in or drop in style bulb?
If it uses the drop in style all you need to do is get yourself a P60 sized drop in. You may need to solder s spring to the positve terminal on the drop in in order to make contact with the cells.
