Custom Surefire® Lego Parts M|C|Z|P|G: Adaptors, Extenders, Bezels, Bodies, Tailcaps
ElectronGuru
Oregon
New to the CPF community?, click here to register
Threads
Contents
Intro
Adaptors / Extenders
Bezels
Bodies
Tailcaps
Ordering
Notes
Intro
Presenting for your consideration, Surefire parts, ready to finish your special project. All SF extensions and bodies are customized to accept 18mm cells, providing maximum flexibility and runtime in your favorite tactical Surefire models. All parts are brand new and ready to use.
Status: All new adaptors, extenders, and bezels ready to ship
Just pick out what you want and head to our Ordering section to complete your purchase
Want to order from multiple threads, just pick your favorite and paste all the lines into a single post
A CPF community production: engineering by Moddoo, color by FlashlightWidow, testing by Sgt. LED
General Features:
  • bodies and extenders receive second tailcap O-rings, from Lighthound
  • Complete component control, build your dream light
  • Durable OEM & custom finishes and features
  • Complete OEM parts and accessories compatibility
Bore Features:
  • Smooth to the touch professional millwork
  • Retention lip to hold 18mm cells inside body when head is removed
Surefire Adaptors
Operate P60 (6P, C2) style drop-ins (and bezels) with E series bodies (E1E, E2E)
E to C adaptor, factory type III (HA) aluminum, 16 grams
Please click image to select
Surefire Extenders
1.0 123 extender (A19) converts your 6P into 9P and your 9P into a 12P. Compatible with P, C, and Z series lights
18mm diameter is suitable for running two 18500's with a bored 6P and two 18650's with a bored 9P
1.5 123 extender (A14) lets you run three 18500's in a 9P/C3/Z3. Compatible with P, C, and Z series lights
18mm diameter is suitable for running three 18500's when connected to a bored 9
Bezels
Surefire Bezels (heavy duty)
These are longer, wider, and even tougher than normal bezels
The integrated shock ring also adjusts to longer drop-ins and/or non SF bodies, for a tight fit
Available in a variety of type II and type II (HA) finishes, both factory and custom
Includes Malkoff's new rubber fitting ring for use with LED modules (see FAQ for more information)
Surefire Bezels (normal duty)
Bodies
Surefire Bodies (bored - factory type III)
bored M3T-HA body only (same as M3 body), type III (HA) aluminum
bored C2-HA body only, type III (HA) aluminum, 55 grams
Bodies (bored - factory type II)
bored Z2 body only, type II aluminum
bored 9P body only, type II aluminum, 81 grams
bored 6P body only, type II aluminum, 58 grams
Tailcaps
Standard Tailcaps
See our Custom Upgrades thread for even more tailcap options​
Ordering
Please follow these steps:
1) Click image(s) above
2) Configure as desired from Options pop up menus
3) Click Add to Basket
4) Click View Basket
5) Select shipping
6) Check out
  • No account required
  • Special orders available, PM for a quote
  • 30 day satisfaction guarantee (refund/replacement, less shipping)
Notes
  • Weights given are approximate and absent of battery & light module
  • These parts can be expected to work with AW batteries, Malkoff drop-ins, and FiveMega drop-ins.
    They are not tested with and may not work with other brands.
  • While purchased new at retail, these lights are modified and may not be eligible for warranty service.
  • While tested for strength and durability, including drop and crush tests, bodies are modified from their
    original specifications and cannot retain all of their original strength.
  • All items are made/modified in USA unless otherwise noted.
FAQ
  • What's the new inside diameter?
    All bodies and extenders are bored to an inside diameter of 18.65mm (funny coincidence with the # 18650 but not related)
  • What does the rubber fitting ring do?
    M2 bezels are designed to allow drop ins to travel forward during extreme backward movement, as with recoil when mounted to a weapon. During this movement, the drop in may loose electrical contact with the body, momentarily turning off (flashing) the light. The fitting ring minimizes this movement, keeping less fragile LED modules in place. In practice, it solves/prevents connectivity issues with certain bezel/dropin/body configurations. Most do not need it, so its provided just in case.
  • Do these work with the new 2600mAh cells?
    As shown here, these parts are meant to work with AW's incredible 2600mah 18650. However, there are minor cell to cell variations, so while most (90+%) easily fit: A few dozen inserts and removals can be expected to wear and flatten the label enough for it to more easily slide in and out. See terms above if not.
Please reply or PM with any questions
:devil:​
Re: Custom Surefire® Parts M|C|Z|P|G: Extenders, Bezels, Bodies, Tailcaps
Your organizational skills are extraordinary!
Happy Thanksgiving All
Zach
Your services are very good and useful for all of us! :thumbsup:
Keep it up!
Cheers,
Dioni
Re: Custom Surefire® Lego Parts M|C|Z|P|G: Extenders, Bezels, Bodies, Tailcaps
Now available:
More FYL bodies ready to ship
LightJunk,
Orders shipped!
:thanks:
:takeit:
#3 - 17670 G2-body florescent yellow - $27 available
Priority box + insurance
Paypal has been sent.
wacbzz,
Order shipped!
:thanks:
Iliger,
Order shipped!
:thanks:
lovecpf
I'll take 18340 A19 cell extender - $36 when it would be available.
lovecpf
Reservation added
What's this?
A sure sign of my continued obsession with this part! :duh2: :rock:
I'll know more when I get the first one. (1-2 weeks)
PS - bore batch C is launched, please email my payment address soon!
So you don't know what TN stands for? Curious.
EDIT: It's Tan.
Email sent.
wacbzz,
Order shipped!
:thanks:
Received today. Thanks again. Both items are in great shape. The insulation is a great idea.:thumbsup:
Now if I could just "re-find" that post which shows with pictures how to take the old part out of the SF tailcap with the hammer and punch and then install the McClicky switch...:thinking:
Awesome. Thanks again.:twothumbs
Dan, in the pic below shows a SF C2 wich you're selling in other thread.
is that tailcap a Z41-HA-BK?? :thinking:
Is there some of these to sell separated?
Thanks! ;)
Hi Dioni,
That is a variation of the Z59/clicky, in factory HA black with a narrower knurling band.
I'm planning to add these as a standard item next month but have one I can share now. PM sent.
If you're interested in an HA twisty, we can install a twisty mechanism into any of the shells listed here:
http://www.candlepowerforums.com/vb/showthread.php?t=248609
Thanks,
Dan
zygibajt,
Order shipped!
:thanks:
