DR_MARK
Probem: Customized Surefire application using MN03 bulb powered by 6VDC 1400mA power supply burns out from power surge.
Anyone have any ideas for a protection circuit that could be used to prevent surges from causing the bulb to burn out?
e.g.: a resistor in the circuit to DIM the light or a fast-burning fuse?
I tried a rheostat in parallel with the bulb. Rotating the rheostat caused the metered output voltage to drop, but the bulb would not even illuminate when the rheostat was at maximum "open-least resistance".
