I don't think of parting on the lathe or the band saw as exclusive. I actually see both parting methods as being complementary.
- For parting of a piece of a longer rod, to then chuck on the lathe for some operations/process, about 99.9% of the time it goes in the band saw.
- For parting of a finished piece, 99.9% of the time I part on the lathe for smaller parts. For anything larger or "iffy" (like a solid rod of over 1" dia), I then grove on the lathe, cut on the band saw, and then finish (face off) on the lathe.
For example. I am about to make these Bearing Bronze retaining rings for the Sunwayman V10R/V11R LED light. I cut the 7-8 inch piece I need in the band saw, and then start working on the lathe with it:
But after making the parts, the finished pieces are cut on the lathe:
But parting on the lathe requires the right setup and cutting tool. Not to start a religious war on inserts vs. HSS, but in "my opinion", anyone starting today as a machinist should skip the HSS and grinding, and head straight to inserts. Specifically, the parting tools using inserts are superior to HSS not only on being ready to use ("never" having to adjust the blade "is" a huge factor for me), but also far more durable, come with various built-in chip breakers, correct coatings for various metals, etc.. Except for cost, inserts are the way to go, hands down.
I particularly like the Do-Grip from Iscar for the thicker blades and deep cuts (1.5" to 2" dia), but those inserts (although strong) are .118" wide. I also sometimes use a solid carbide tip (M100 micro carbide) which is very, very sharp, but it is 0.125" wide at the cutting tip for cutting Delrin rod up to about 2" in diameter. Although my setup is very rigid for these "wide" blades, and I don't have problems with an insert that wide on my 12x lathe, it does waste a lot of material, specially when making several back to back parts that are thin (some 0.025" thin). So, I am now using a much thinner blade/insert from Iscar whose inserts are only 0.063" wide, and SHARP!
Here are both the solid carbide cut-off blade on the left (0.125" wide) and the 0.063" wide Iscar:
And the narrow cut-off blade in action:
Will
