Tekno_Cowboy
I wasn't quite satisfied with the tint of my Nitecore D10, so I decided to swap the emitter to a Cree Q3-5A. Here's how I did it.
Click to view larger images.
I removed the ring with a 90 degree pick:
Then I removed the pill by lifting the driver with a pick, and then using a needlenose pliers to turn the pill out. I had previously broken the pill loose; it had been glued in.
I removed the LED it came with with my Hakko 936. I've pulled apart several LED pills/drop-ins lately, and excessive thermal grease seems to be a common occurrence.
I cleaned off the old thermal grease and applied a thin coat of Arctic Silver 5 to the back of the LED's PCB.
I soldered the negative lead to the negative terminal, and took some measurements:
Off: about 100mV
Min: 4.12V at .3mA
Max: 3.89V, 500-625mA
I got an unusual reading when measuring the current at max. From cold, I got about a 500mA reading, which very quickly rose to 575mA, then slowing down over the course of 10 seconds as it rose to 625mA before I removed the test leads. If anyone has any idea what might cause this, please let me know.
After I was done with my measurements, I finished soldering the led:
I added a small amount of Arctic Silver to the threads to improve heat transfer, and reassembled the light. I made sure to clean up the excess and relube the light before using it.
The light seems to work fine, and the tint is just right: Smack dab in between my Surefire 9P(with P90 bulb) and my Wolf-Eyes Raider(with a R2-WC LED). :D
If I can get a hold of some Teflon insulated wire, I might swap the wires as well. You can see how the insulation is starting to melt away from the conductor.
Since I already removed the led, I plan to toss the LED the D10 came with into a pill, and use that for side by side comparative beamshots. Beamshots to come :D
Off: about 100mV
Min: 4.12V at .3mA
