+1 on that, in fact, certain types of physical damage can make a protected battery :poof: while a unprotected one wouldn't - due to positive and negative being separated by 0.1mm thick tape, which is very easy to get worn through.
Hopefully you'll have better luck putting the point across as it seems that my attempts have fallen on deaf ears so to speak :D
I hope we can agree to disagree, without being disagreeable ;) ... but you have again linked to a failed unprotected cell, an IMR in this case (which are generally not even available with a protection circuit). Although I too don't have time to read through every post in that 17-page thread, or attempt endless web searches to find a counter-example, that particular case appears to have been a short across the leads by a metal eyeglass case ... a short that the PCB on a protected cell might have prevented :thinking:
Absolutely as i said i'm not here to hold any ones hand.
People should make their own risk assessment (after searching and reading up) and whatever they feel will get the job done.
On my TK35 the battery tube is generously sized so i se protected cells.
On my SC600 it's one from the pre-ordered batch so the battery tube is VERY tight on ALL protected cells, so i use unprotected and have been doing since i bough the SC600, so daily use/carry for well over a year without blowing myself up :naughty:
So i'm not saying one is better than the other, they both have their good and bad points.
The only point i'm trying to put across is that protected cells when used together with a quality charger and a quality torch with a low voltage cut-off are no safer than unprotected cells.
I'm not recommending people sell all their protected cells and move over the unprotected, i'm not saying one is better than the other.
I'm just pointing out that the risks are STILL there no matter protected or unprotected and IF parts of a protected cell fail it has the potential to destroy the cell.
To sum up
Protected
No voltage cut off needed on the torch
A noggin safer when charging on lower quality chargers
Bigger diameter
Longer
More expensive
If certain components fail in could lead to catastrophic failure of the cell
Unprotected
Cheaper
Smaller diameter
Shorter
Lighter
Bit of a cheat as it's really as a result of all 3 above, but in my case more mAh yet still fits (1st gen SC600)
No circuitry to go wrong
Requires a torch with low voltage cut-off
Require a quality charger
Both Protected and Unprotected
NEEDS to be treated like you would an egg when out of the torch in case of physical damage
NEEDS monitoring when on charge at all times
NEEDS charging outside or in a well ventilated area with nothing flammable anywhere near it
NEEDS storing safely (i keep my cells in a small petty cash tin, in the fireplace when not in use)
WILL dramatically fail if overcharged
WILL dramatically fail if physically damaged
That about clear up my thoughts and advice on the subject.
To anyone that doesn't know me or have read my previous posts i have been using lithium batteries several times a week for around 10 years now in radio controlled craft.
I've bought everything from cheap Chinese cells, expensive American brands, from 1S to 10S (42v charged) configurations, i would guess over the years i have bought easily over 200 batteries in all formats and chemistries that are all commercially available.
I certainly would not say i'm anywhere near an expert or even a well informed amateur compared to many of the various RC forums, but i would say i have a interest in batteries and enjoy reading and experimenting.
