derrelight dbs v2 3SD versus 18650's arrgh!
lurcher
I have a derrelight dbs v2 3SD running protected 18650 trustfire and ultrafire batteries. I charge with a pila charger. I have tried not to thrash the batteries
The darn thing always cuts out on high power really quick. Is there a better battery out there that is compatible with the pila charger that will give a decent run time? I would rather not get the extension tube and run two batteries if possible.
Cheers in advance
Two batteries in series will fry the driver in that module, so I wouldn't try that.
What is the voltage of your battery when it comes off the charger?
Why would dereelight sell an extension tube for the dbs if two batteries would fry it?
I'll check the voltage......
