Hi again Jeff,
That's a very nice little circuit.
It looks very safe for the LED's
and the adjustable brightness gives you
much longer run time i bet at lower settings.
I dont think you will want to use that
digital pot because it will draw in too
many other support chips. I like the
idea of just using a pot though, and you
can find one of those small ones that
should be smaller then an ic chip, or maybe
about the same size as an 8 pin dip package.
Ever see those kind of pots? They adjust
with a screw driver, but they turn pretty
easy so even a key would work i bet.
I was going to put one on my two LED light,
but instead i ended up using a dip switch
with about three different resistors that
get switched in or out. If you work the
resistor values right, you can get 16 different
levels with only four resistors and four
switches, although i guess you dont really
need that many levels :-)
The LS simulator was just made by connecting
three 1N4001 diodes (or 1N400x diodes) in
series and then a 1 ohm, 1/2 watt (or better)
resistor in series with the diodes.
The LS anode is then the anode of the top
diode, while the cathode is the free end
of the resistor. That's the simplest
simulator and works fine for testing circuits.
The voltage is just a hair under the real
LS voltage, so if you want you can add
a Schottky in series with the other three
diodes also, but i didnt find it that
important during all of my tests.
Take care for now,
Al
