Am I right to be disappointed with my new batch of Eneloops? I just purchased 20 new AA's from T-D, the same place I purchased most of my original stash back in 2006 (I think...)
These cells were packaged in flat packs with foil backs instead of the incredibly over-packaged plastic cases from 2006.
The original batch which is basically batteries #1 through 68 all tested between approx. 1980 mah and 2100 mah on a refresh & analyize cycle fresh from the packaging.
(EDIT: My R&A Cycle is always using 1000 mah charge and 500 mah discharge)
Last night I ran an R&A cycle on the first pack of new ones and got the following results:
#69 - 1793 mah
#70 - 1788 mah
#71 - 1825 mah
#72 - 1800 mah
Now to be fair about my comparison, the charging environment has changed in these aspects:
1) The original batch was tested with an R&A cycle on a 1st generation MAHA C-9000 charger purchased on pre-order from T-D, and the new ones are tested on the same model, but replaced by T-D approx 6 months later and is known by CPFers to report lower capacities.
2) The charger was plugged into a 240v source since I was located in Germany with the original batch, and is now in the USA with a 120v source. This shouldn't affect charging or discharging since the charger should be getting the exact same DC voltage regardless of the input voltage and frequency.
Another fact: My maintenance routine for my batteries is to do an R&A cycle on the first charge of a calendar year. Last week I did an R&A cycle on a set of four original batch batteries and all four tested in the same range as the new ones. I can't compare these results to the original R&A because of the charger change, and this was only the 2nd R&A cycle for this batch since they were wasted by being used in my laptop mouse and keyboard and hadn't needed a recharge since I purchased them!
So... I have no intention of returning the batteries because I know regardless of their measured capacity they are the best for my uses, and they match what the original capacities are now.
I'm just looking for your opinion on this, and possibly if anyone else has measured the capacity of newer Eneloops on a C-9000 and get similar results?
Thanks,
RobSpook
PS - Eneloop + Fenix LD10 = :thumbsup:
#69 - 1793 mah
#70 - 1788 mah
#71 - 1825 mah
#72 - 1800 mah
Thanks,
RobSpook
