radellaf
Any idea what's going on with this pack? At the 1C rate it looks normal, but look at the start of the .1C "recondition discharge" The curve is like, backwards.
FWIW, running these cycles on the UBA4 has brought this pack from about 1.3Ah back to the 2.2Ah rated capacity. Don't know if more usual 1-stage discharges would do it, but this does a 1C discharge to .9v/cell then .1C to .5v/cell.
Other odd thing - adding the capacity of both discharges should be on the order of the pack capacity, but in this case I got 500mAh or more over the 2.2Ah rating. ???
One Hour Discharge
Duration (h:m:s): 01:00:54
Load current: 2.205A.
Cut-off voltage: 900mV.
Battery discharged: 2.237Ah.
Exit condition: Battery cut-off voltage reached.
Recondition Discharge
Duration (h:m:s): 02:34:50
Load current: 216.5mA.
Cut-off voltage: 500mV.
Battery discharged: 558.6mAh.
One Hour Discharge
