I have several 5000mah Tenergy Premium C cells I plan to discharge and then recharge to see if their capacity has degraded over the 5 years I have had them. I have read to discharge them using .9vdc per cell at 1C (500 ma). Is this the correct numbers I should use? I am using a 10 cell holder with a couple of Hobby Chargers that enables me to discharge 10 cells in series in order to speed up the process. So using the .9vdc for ten cells I would set the discharge voltage cutoff to 9vdc?
Any suggestions or corrections??
Bill
Bill
