- price range: $100.00 to $150.00
- runs on 18650 battery
- Throw at least, AT LEAST, 50 meters.
- A "decent" runtime
Is it possible something like that? It is for some caving activities, and it needs to be tough.
Thank you, guys.
50m, is that on land or in water? I can't see a light throwing 50m under water to be very useful. Being able to see the light from 50m away is something different, but very difficult in murky waters, even with heavy HID lights. I don't think this requirement is very useful other than that it should have a small-angle-beam.
not sure if I would depend on a 100$ light in a cave though, but I never did any real cave diving so don't shoot me for saying this.
a decent run time depends on the emitter that is used, the number of 18650 batteries and the capacity of the batteries (also a little on the efficiency of the driver if a LED is used as emitter).
If you know how much power the emitter (+ driving circuitry) needs, you can easily calculate the approximate run time.
for example, a SSC P7 LED on 2 18650 batteries of 2500mAh with a 2.8A dealextreme driver (not the most efficient drivers).
if the forward voltage of the led is about 3.5V and running at 2.8A, it is consuming 9.8W (just multiply). The batteries can provide 8.4V (when fully charged) and have a capacity of 2.5Ah so that would give 21Wh. The LED would be able to run for about 2h (21Wh/9.8W). However, if one includes the driver efficiency (e.g. 80%), the LED would be consuming 12.25W and runtime will be about 1.7h. knowing that the batteries don't stay fully charged, you'll be getting about 1.5h of runtime with this configuration, which is actually pretty accurate according to my testing.
I find this a decent runtime for 1 recreational dive (or 2 if not using it at full power or not for the entire dives at full power). If you can indicate what a decent runtime means in cavediving, I think we could suggest some usable configurations. not sure if this will be very usefull though as commercial light don't always give these details, just the runtime or light output.
