MWClint
Inspired by Blindasabat's original 2 Level Peak mod. thank you!
requires a few parts,
A peak light with keyring body,
A peak momentary switch,
1/4 watt resistor of your choice,
and a Brass Finial from a lampshade. (preferably acorn style nut or flat topped nut)
the hole in the nut from the brass finial is a perfect shape to fit around the
spongy foam in the peak switch.
you will need to grind the top surface of the lampshade finial to a few
thousands of an inch. to do this quickly, I taped the finial to a dremel bit
and spun it against a metal file. checked it periodically with a micrometer
until i got it down to .015" This is plenty thick and yet still thin enough
to allow you to use the original sized battery in your light.
then grind the base of the finial, so that it's 1/2mm shorter than the height of
the spongy battery spacer.
now, remove the plug and spring from the tip of the momentary switch.
(comes out easily with a twist)
grab a 1/4 watt resistor(value depends on your intended decrease in
brightness) and cut off both leads. sand the ends of the resistor flat.
wrap resistor with a little tape and twist it firmly into the momentary switch.
press the brass finial over the spongy battery spacer and then screw the momentary back into the light.
A twist of the head will yeild the original brightness of the peak light...while a
press of the momentary will yeild your lower resistored brightness.
(if a twist of the head makes it come on low instead of high, you need to
sand down the ends of the resistor a bit more.. the top of the resistor needs
to sit BELOW the top of the sponge; you can sand the resistor down pretty
far before you ruin it.)
video of the 2 modes in action. :devil:
http://www.v6power.net/clint/lights/rainier/rainier.wmv
Rainier w/2AA body and momentary. (will work with the rcr123 body w/
momentary as well..or any peak light with the momentary)
14500 + AAspacer works great in the 2AA for 1 amp seoul p4 goodness.
2 14500's wired in parallel would be killer in this body with the 2 level
momentary.
pic of the momentary. the 2aa momentary is larger than the single
cell momentaries. probably to allow peak to easily drill the brass tube from
both ends for the multi cell lights. the momentaries all work the same anyway.
brass finial cap - cut down to size
finial installed showing required gap.
momentary switch with the plug and spring removed from the tip.
resistor is in the background.
resistor securely in place.
showing the required gap between resistor and top of sponge.
momentary with resistor and finial cap installed.
Now to order more momentaries to do the rest of my peaks!!!! :naughty:
:thinking: hmmm.. will have to drill some holes in the base of the lights for lanyard + split ring attatchment. Luckily, the keychain bodies have plenty of
meat in the tail.
momentary.
meat in the tail.
