yo6ial
Hi.
As I have some ideas to make aluminum cases for led lights, I'm searching for more info about possible home-brewed casting methods. Moreover, i think i could make even aluminum reflectors, using some polycarbonate led lenses as die templates.
My setup, for now, is an electric kiln, aluminum scrap and two tons of drawings and designs
I intend to make simple ceramic dies, perhaps starting with the lost wax method.
But, if all this will be relatively easy and the processes involved are well understood by me, i don't intend to let those cases in they're natural color.
After some mandatory milling, and polishing... some protective black color will be a must.
Anyone knows some homemade methods of anodizing? (ok, not quite homemade but more of a small shack)
And the reflectors, witch will be the first I'll set myself on.
Molding, cleaning, milling, polishing and... here comes the hard part, coating.
I plan to use the electronic deposition method, as in a vacuumed charmer, the part is connected to the positive side of a high voltage supply and an electrically heated cathode will heat the metal to be deposited on the reflector.
What metal should i use for reflectors coating?
Can I use Chromium or Nickel, on top the copper 1st coat?
What metal is used in coating those marketed aluminum reflectors?
Thanks for reading
Thanks for reading
