some external resistance can make more differance then the internal resistance
if you use the same brand same batch, and same time cells, and they are good cells, and you CHeck them before assembly, everything will be fine on the parellel side, untill they are no longer good cells. and heck you got balancing and seperate charging to keep everything together. i really would use some good Name brand reliable cells like LG or sony or sanyo, or pana, and not that junk that gets sold if you are worried about the parellel and the time it would last, and i would not worry so much about excessive capacity, a good 2000-2400 cells are built well.
indeed when your parellel dont USE all 2X of what you have, meaning dont parelell it up 2X if you want to get 2X the specs out of one, if your going to shred one, so your using 2 , use 3 or 4 , and keep the whole thing doubled up over the max specs, that way if it leans a bit more into using one cell or another after well aged, it dont matter so much..
you know you can make a Li-Ion charger that ramps beutifully if you use a FAT voltage regulator like the big fat 8 amp one, so nothing goes wrong, and a fat linear transformer. then you can stuff fat amps in at the first of charge, and it slows down as the voltage differential is reduced.
then if you put a pulser in, you get the best of all worlds potentially you could run a 50-50% pulse to each battery , and charge BOTH with one linear voltage fixed charger, switching back and forthe with DPDT to both batteries.
you get a charge to 80% in a few hours, and with the max voltage LOCKED out to 4.2v it never goes above.
i mean if your gonna tie a bunch of crappy chargers together, might just as well make your own, its like 3parts to make it and 3-4 more parts to make it clean and steady. and its not that much harder to assemble than 4 crappy chargers
it just wont fit insides the light then.
