Fallingwater
Or, in other words, when swapping in a SSC, do I have to worry about insulating the slug or do I just put the conductive spacer in its place and I'm done?
Thanks.
Thanks.
Just tested an emitter I am sure is either a lux 1 or 3 and the slug seems to be electrically isolated from the LED neither + or - would light it up through the slug.
by my simple test it appears to be unable to be used as either + or - to complete the circuit so I would guess that means it doesn't conduct which means you could heatsink it to a surface of either polarity as long as the other polarity is insulated.
I've no problem if the slug conducts negative - actually you could use conductive thermal paste and do away with the negative wire altogether. But a positively conductive slug is just dumb.I had one other thought.... it is quite possible in the specifications they allowed for future possibility of having the anode or cathode electrically connected to the slug like the SSC P4 does. Convincing people to electrically isolate the slug would make future manufacturing designs and replacement less of an issue.
I wonder if having it conduct helps the heat transfer better or not?I've no problem if the slug conducts negative - actually you could use conductive thermal paste and do away with the negative wire altogether. But a positively conductive slug is just dumb.
