Re: Does it make any difference how you put parall
Hello there,
If i was going to do this i would use two parallel strings
if i was also going to run the LED(s) using series resistors.
That way i could use two resistors (instead of 1) each of
twice the required value (as for one string) with each one
in series with one of the strings. Each string would then
be supplying half the current for the LED(s).
For example lets say we're using two strings of 4
alkaline batteries. Each string comes up to 6 volts.
Lets also say we want about 270ma flowing though
one LS LED, which itself runs at about 3.3 volts.
Now one string alone would require 10 ohms, but
we want to parallel two strings, so we use 20 ohms on
each string and connect the two free ends of the two
resistors together and connect the LED there.
This gives us plenty of isolation between strings yet
allows us to parallel the two strings rather safely.
If i was using rechargeables instead of alkalines i would
do basically the same thing, except the resistor values
would come out a little less because of the reduced
voltage.
To charge the two strings, they really shouldnt be in
parallel anyway, but it might work to leave the two
resistors in place and replace the LED with a charger with
a slightly high voltage then usual to make up for the
loss across the resistors, or simply make a charger with
two outputs and connect the two strings independently
for charging only.
Another thing you could do is check the current between
strings after you connect them to see if one string is
trying to charge the other string. This will occur if
a cell in one string is low compared to the other string.
For this the Schottky diodes would work out pretty well.
At least with the diodes if one cell goes low the other
cells dont get 'charged'. This will be a problem if using
alkalines because the other cells will go bad also, but if
working with NiCds it probably doesnt matter much.
Take care,
Al
