I can confirm what KuanR has said. It is a double ended threaded tube. Mystery solved!
Brilliant! ... now do I buy the charger as well?
well.. i cant get my titanium hobi to open any other way than like i said. so cant make it into 3 pieces. my fingers hurt from trying.
I need that charger. Right now I use Quantum's usb charger.I've got my Hobi now. First impressions, too nice to put in my pocket. It's going to be pretty abused in there with keys and stuff.
The package came in a plastic box
Here's what I got. Some glow in the dark o-rings, split ring, the Hobi, the charger and the two more batteries.
It turns on! ... but wait, only one mode?
hmm, ok, let's charge up that battery and see what comes of it.
There one thing I have to say, the threads are tight. Without the knurling it makes it very hard to twist. Going to see if I can lube it up and see if that is any better. Even had a hard time twisting the charger on.
I'm assuming that it only has low mode at the moment, but it looks like quite a bright low. If it is 20mA, it is brighter than a Fenix E01.
Edit: OK, it does have two modes. It took quite some tightening to get high. There is some thread play as well so needed to loosen the head quite a bit to stop this from happening. Hmm, neck wear perhaps?
The tightness of the thread on the body affects the twist-ability of the head and the charger but I think that is just my sample. Can't complain as everything else is good but might find ways to help with grip. I was going to lube the o-ring but due to the thread play, but I have to untwist it quite a bit to keep it off, and a further twist means the head is too loose.
thanks, I wish I could see pictures of both SS and Ti together. I think I will be going for the Ti (unique flashlight, kind of unique metal....).
