Driving 2-4 Cree XRE (and similar) using regulated/switching wall warts?
redfishsc
Noob question here.
If someone wanted to drive just a few XRE type LEDs (ie, ~3.5v around 750-1000mA) would a properly selected wall wart--- either switching or regulated--- be fine.... without getting into very complicated DIY voltage reducers etc...?
Speaking in terms of non-dimming.
Say for example if I had a 9 or 10v regulated/switching wall wart at 750 mA (or similar), would that reliably run 3 XRE's at 750mA in series.... or am I confusing the way voltage and current is affected by series vs. parallel circuits?
If the wall wart is regulated/switching, would any variance in the AC input (from the wall) translate into enough voltage noise to damage the LEDs?
Or.... do these LEDs need to be given a true 3.7v each?
Any advice is appreciated. I currently have an 8 XRE array driven by a Meanwell that has been working beautifully, but am looking for the simplest way to drive just a few XRE's.
Thanks!!!
Noob question here.
Thanks!!!
I did a similar project using the LM317 transistor from Radio Shack. It's easy to wire, I wrote up the lap I made here. I used a wall wart, two switch (Power and Hi/Low), the transistor, and resistors. Cheap wall warts tend to drift in output and burn out if run at their limits.
lamp project. I used 1 XR-E, but that's because I only wanted one. For more in series, I'd use a higher voltage wall wart with no other changes.
Be sure to connect the LED+ to Vadj, as Vout gets the resistors on it.
I know about those cheap wall warts. I have a small pile of 12v that actually give from 14 to 20v (no load). Fine for driving computer fans and such, where some voltage noise isn't a big deal.
The question I have, I guess, is this. If your wall wart is regulated or switching-- meaning it actually puts out no more than about 0.2v over it's rating--- wouldn't this be adequate protection to not need an LM317?
I have several 9v supplies that are either switching or regulated and I've tested them all with no load, several times, and none of them give me over 9.14v.... and it doesn't seem to fluctuate much.
Is it not possible to drive small numbers of LEDs with these types without risking a major :fail:?
(cool desk lamp build btw!)
Is it not possible to drive small numbers of LEDs with these types without risking a major ?
I haven't tried it that way. You might want to test the wall wart under load - If you've got a big resistor that's one way. But as long as its voltage is always:
1) Stable
2) Less than the Vf-at-maximum-load of the LED string
you'll be doing ok. The voltage you happen to have may not grant the highest output, but it'll work with those conditions met. LEDs driven at higher current increase their Vf, so it will reach a balancing point (See 2, if the balance point is above 1 amp you can toast the poor things)- but the Vf range can bite you with a small number of LEDs in series. Supposing that all three of yours are low, you may be in trouble.
An XR-E Vf has a typical 3.3v 350 mA, rising to 3.5v at 700 mA, and about 3.7v at 1 amp. But even at 350 mA the Vf could be as high as 3.9v. I don't know what you've seen about LEDs, but all that really matters is the Vf of the string of LEDs, which is affected by the current they see.
1 XR-E has an expected Vf of 3.3v@350 mA, 3.5v@700mA, and 3.7v@1000mA. This gives 9.9v, 10.5v, and 11.1v as typical values. Since your wall wart can only give 9 or 10 volts, then you'd be limited in the current the LEDs could get. Let's say you have a 9v supply - on average, each LED will get about 3v (it may be a bit higher with the reduced load, but this is more the case with cheap wallwarts). Page 7 of the datasheet tells us that at 3.0v, the LED will take about 150-200 mA of current. You can predict the brightness by going from the voltage each LED sees, to that drive current, to that luminous flux, then multiply by the rating at 350 mA. 10v won't be very bright, you'll be seeing about 60-75% of the lumens at 350 mA. One advantage is that the LEDs would be extremely easy to cool, hardly strain the wall wart, and they'd be very efficient. It's just a shame to get nice LEDs and hardly get them going.
You could get significantly more light with the LM317T setup running 2 LEDs in series. This would run the two LEDs hotter and use the wall wart's output more effectively. Setting the resistor for 700 mA requires:
1.25v/R ohms=current
1.25v/R = .7 A
1/R=.7A/1.25v
R=1.25v/.7A
R=1.7 ohms (2 ohms would give 625 mA)
This would deliver about 150 lumens per LED rather than 60 or so. If you don't need that much light, there's no harm in running LEDs quietly with the wall wart in direct drive.
Summary: If wall wart is stable in voltage, the LEDs will only take a certain amount of current dictated by their Vf - it changes, but is around 3.3v per LED. 3 XR-Es in series will give about 60 lumens with 9v, and a bit more with 10v, and above 11v you are running at the edges of what the LED is rated for (The first problem you'll hit is heatsinking). Good heatsinking will pay for a lot of sins in setting up the LEDs, but don't plan on more than about half a volt too much per XR-E, unless you like excitement.
Good luck!
Edit: For other projects on cheaper wall warts, they tend to go over-volt with no load. If you put the power switch on their AC leg, they won't ever have no load while powered.
Edit2: For pronoun clarity
Wow, thanks for that post. Things are making sense now.
I see on that chart how just a a few 0.1v's make a HUGE difference in the current draw. Now the need for a voltage regulator makes crystal clear sense.
So, how does the Meanwell determine how much current/voltage to send to the LEDs?
In other words, if a Meanwell is rated at 700mA (non-dimmable), does the Meanwell simply alter the voltage output to about 3.5v per LED (increasing by 3.5v per LED added, up to the max voltage)?
If so.... what if you had XRE and XPG on the same circuit? I have been told you can mix LED's that have the same/similar forward voltage. But at 3.5v the XPG should draw nearly 1400mA, yet the XRE is 700mA.
I appreciate your responses, VERY helpful Applesnail!!!!!
The biggest problem you'll run into with resistors is that resistive voltage modification is wasteful, and you rarely have the voltage you want. If you get 10v and cut it down to 6.6v to drive two XR-Es at about 350mA, you've got (10v-6.6v = 3.4v) going to waste. 3.4v times the drive current (.35A) equals waste heat at the resistor - 1.1 watts out of 3.5 watts of power are pure waste. If you add an LED to that setup, you get dim XR-Es, outputting about 60-70 lumens apiece. You'd have to drive a pair of LEDs (saving you $6 for the LED left out) at just about 500 mA to get more light. Spending about $2.30 for the LM317T at Ratshack's high prices is well worth it, especially if you aren't lucky enough to have good wall warts. Let me emphasize - you could solder the wall wart +DC to the first XR-E, the other two in series, and back to the wall wart - that'd work fine, especially if you put your switch on the AC power.
Constant-current drivers are, to me, magic. They do feedback of some kind to maintain a constant current output no matter what voltage is required (within their own limits). LEDs want constant-current, while incandescent bulbs want constant voltage; LEDs are sensitive to voltage while bulbs die from small current changes. Given a particular voltage (as in high-end lights), an incandescent bulb's resistance defines the current, at a level that won't blow it out. With LEDs, a particular current is what you care about. The LED's Voltage and Current are exactly related - no matter the voltage, if only 350 mA goes into an XR-E, it will see 3.3 to 3.9 volts. On the other hand, if you fix voltage on an XR-E then because of the Vf; varying from 3.3(typical) to 3.7v at 350 mA, you have little idea of what current the LED will see. The LM317 keeps 1.25 volts between the Vadj and the Vout pin - putting a resistor there defines the current pumped through the chip (up to its voltage, supply, and wattage limits). Meanwells work with a different electronic setup to do the same thing - set any voltage necessary to maintain the current selected.
The Meanwell driving one LED will pick out its forward voltage at that drive current (within the limits of its precision to drive at .700 Amps). If it drives two LEDs then it will step up voltages - so don't have a switch adding and subtracting LEDs from a string to cleverly dim a meanwell - it may not adjust voltage quickly, and your dimmer might smoke the LEDs left in the string. The LM317T imparts a voltage drop to do its work, making it no good for flashlights. Think of regulation as holding a stack of books at an exact height. As long as the stack stays the same, it's easy to keep it in place. But then some goofball throws books on and takes them of - only very strong people could keep their hands very still, and only fairly nice electronics will adjust quickly enough to save the LEDs. This includes powering up a driver without a load on it - shorting it out can fry some driver's electronics, and connecting some to an LED while the driver is powered can kill the LED - it was trying to push its rated load through a air gap - it'll never reach 10000v per inch (between LED+ and LED-), but it'll charge to the highest voltage it can, dutifully trying to push its current. Then you'll toast your LED string and be sad (Voice of experience!). With that said, generally you would connect the LED to the driver and then power up the driver, and if you mess up the order then unplug the driver and discharge any capacitors it has through a resistor.
Mixing LEDs.
Mixing LED Vf IN SERIES works acceptably, although it can get icky from an efficiency standpoint. Let's say you have an XP-G and an XR-E, they usually have different Vfs (I'd be surprised to find a matched pair). If we drive both with constant current at 350 mA, the XP-G will have 3.0v(typical) to 3.75(max) Vf. The XR-E will have the 3.3 to 3.9 Vf. If we put these in parallel, they will not get the same current. They aren't resistors and I don't know the semiconductor math, but the low Vf of the XP-G will make it suck up much more current than the XR-E. No matter what, I'm driving the XP-G hot and inefficient - CREE LEDs are always less efficient at higher power levels (above 20 microamps), while the XR-E is going to be running at a very low current. Depending on the current imbalance I may burn the XP-G out and then the XR-E will see the whole current and immediately smoke. If the power supply is voltage-based (Batteries, wall-wart), low-Vf LEDs will die and high-Vf LEDs might live - depending on the source voltage.
LEDs in series are more friendly. You sum the Vf, and they all get the same current. It's up to you if you want them to run at the same current; that's a design choice (and affects the light output and heatsinking and so on).
Edit: For LEDs you don't really want to regulate on voltage. Your design decisions for a lamp should be based on how much light you want. Once you pick a particular LED that can deliver that, in a color of white that you want, you pick a current to give you the output you want for this LED - in my lamp I wanted about 150 lumens. With a Q4-brightness XR-E (100 lumens at 350 mA), I wanted 150% of that. Page 8 says that it's 800 mA. So I picked my resistor to make the LM317T deliver 800 mA. If I'd picked a voltage instead, I'd have no control over the brightness, except by fiddling with the voltage. Since wall warts rarely give you the voltage you want, it's kind of a shame to waste $6-per-unit LEDs when another few bucks will give you complete control. In short, picking the current lets you choose how bright the LEDs will be, and ensures that you won't toast them.
Yeah I found out the hard way that the Meanwell ELN60-48 will smoke a single XRE. Apparently it needs a minimum 6 leds to work.
The 60-48 I'm using has a dimmer circuit built into the driver, you just have to supply it with 0-10v DC voltage signal (and a 10K pot) to dim them. It's really an awesome driver that's easy to use... but at $40 a pop for 13 XRE or XPG.... and not much cheaper for smaller versions--- just gets pricey.
Oh, and for heatsinking, I have a few 2X2 CPU heatsinks from an old computer that I figure should be able to handle two or three XRE at 700mA.... hopefully lol...
The LED array mentioned above, with the Meanwell driver, has a 2" by 24" long 3/8" thick heatsink with 1.5" tall fins. The highest temp I've been able to record with an infrared gun (anywhere on or around the LED) is about 95F. That's only latent cooling--- no fans at this point.
I have used switching wallwarts and simple resistors to drive XR-Es. I measured all the voltages and drops under the desired load to calculate the resistor value.
I've used pretty much every driver on the market from Xitaniums to Mean Wells and both voltage and current regulation has advantages and disadvantages.
A current regulated supply has a maxium theoretical voltage that will be discharged under certain less than ideal conditions which can and will toast LEDs. Current regulated supplies also have potential issues when it comes to parallel strings and current hogging. Current regulated supplies also are dicey when it comes to mixing LEDs with big Vf differences. For instance, building a light with a mix of red and blue LEDs for growing plants.
Worst of all, it's rather difficult to verify that a current regulated supply is actually producing it's labeled current. Case in point are the issues with Lux Drive and bucks discussed here. While I trust mainstream drivers like Mean Well, the fact is, how do you know how much current is being produced?
Mean Well has several fixed voltage power supplies in the 12-15volt range for less than $20, and adjustable. There are really good 700mA drivers for less than $30 and will work fine with a couple LEDs.
Thanks Blasterman! Thanks for the info, very helpful.
On my Meanwell, I've always checked the current (when building the array) by hooking the mulitmeter inline with the LEDs (ie, as if it were the last LED) and just took a reading that way.
I assume that the Meanwell is giving the same current with and without the multimeter inline (ie, assuming the multimeter isn't causing some sort of feedback noise that tricks the Meanwell into giving a different voltage or current).
Yeah I think you're referring to the LPC series, which are good.
Fortunately Nanotuners has the ELN60-48D for $33 right now :D which I am partaking of :twothumbs (for driving 13 XPG)
An additional note:
Im sure you also like everyone else has a pile of mobile phone chargers.
As per advice i read here long time ago, most of them are current regualted. Ie they will ramp up the voltage (up to their max) until they are supplying the rated current.
I regularly use an old Nokia charger for quick testing of single or double LEDs in series. Its so much easier than wiring up a seperate PSU,driver, etc.
Although the Nokia charger has a max voltage above the burnout of the LEDs, Ive never blown one, since it just sits at the max current, and the LED happily gets the perfect voltage. Ive tested the current output and its bang on spec.
To retell this previous advice, you need a SWITCHING mobile charger, which are the smaller ones. If its kinda big and heavy, there is probably coils and transformers in there, which would make it a voltage regulated, whihc is NOT what you can play around with safety for the LEDs!
So to sum up, for driving one or two LEDs, the mobile chargers are fabulous!
