Drop in for 6PDL
AR_Shorty
Can I pop out the LED module out of a 6PDL and replace it with a Malkoff M61 or is that only possible with the incandescent version of the 6P? I don't have one, so I can't see if the LED is permanently mounted inside the head.
... if you have the older 6PDL, which uses the 6P Defender head and a separate P60L LED module. The newer 120 lumen version uses a dedicated KX4D head, and the LED cannot be swapped out.
Yes, I should have mentioned that in my earlier post - I have the older 80 lumen version, not the new 2010 version that uses the KX4D. Thanks for the help!
Apologies, I stand corrected... Didn't even think of the latest model! :shrug:
The M61 is a great drop-in! When using my flashlight for short distance applications I have also been getting a lot of joy out of the M60F drop-in.
