Neill_Currie
- Joined
- Dec 6, 2003
- Messages
- 21
Got a couple of Ultrafire 10440 cells from DX the other week to use primarily in a Maratac AAA.
One of the cells is fine through a couple of charging cycles (it's a Trustfire TR001 charger), but the other doesn't charge, and thus acts as if it's flat. When I put the dud cell in to charge, the LED on the charger doesn't even change to red.
The other cell charges just fine in the same charger, regardless of which side of the charger I use.
I have even tried small balls of aluminum foil between the battery terminals and the charger terminals (just so as I can be sure there's true contact), but it never charges.
So, is the cell simply dead? Is there anything I can do?? Is it possible to take the cell apart and effect a change somehow that'll enable charging???
Many thanks.
Neill
Many thanks.
Neill
