Do you have a multimeter? If so, you can use the diode setting. It will light up if you have the correct polarity and will not if you don't. Won't hurt your emitter.
I got rather confused when I got some from there too, because the anode and cathode are the other way around with batteries. http://en.wikipedia.org/wiki/Led has the answer. The little diagram on the right shows that the anode (A) is positive and the cathode (K) is negative. And strangely enough, the diode setting on my multimeter verified that. (Yes, I know not all multimeters have that feature.)I have an led on a board from Cutter. It has only A and K to denote + and - which one is which?:thinking:
