Probably the easiest to make would be a piece of wooden dowel rod with a groove cut or drilled lengthways in it to take a length of copper wire along it and wrapped round brass thumb-tacks in each end of the rod, then wrapped in insulating tape. Alternatively, there are CPFers who make smarter custom dummy cells for sale in different sizes - I don't know the links to these but probably in the "Custom & Mod" section. But never use a dead cell for dummy purposes.
I've heard of using plumming copper cap, forget what they used inbetween the end caps.
I visited the local scrap metal yard and found some 1/4 inch plates. I cut them 3/8 inch strips by 2 inch, which is a bit long and file to fit.
Also acquired some 2 inch long copper nails that I try some time. Thinking about drilling a hole through some 1/2 inch wood dowel then place the nail inside.
In higher humidity areas and when charging at higher currents, I recommend using something other than wood. I found some wood spacers "leaking" when charging at 2 amps. This dielectric leakage was caused by the moisture content in the wood.
Hi, you can use the search function and you will find places to buy some from "litho123" or "AW".
They are already shrinkwrapped and have a good performance.
I make my dummy cells by crumpling some aluminium foil in a cylindrical shape and insulating it with tape. I wouldn't trust them for high current applications, but they are fine for running small applications.
I've used some extra heavy guage aluminum wire cut to the proper length. Got one replacing a battery in an Energizer Folding Lantern out in the car right now.
