These are the new Ion Core Technology Pre-Charged batteries -
they seem to have replaced the "DuraLoop" Pre-Charged batteries
The packs in stores look like:
The AA Ion Core Pre-Charged is rated at 2400mAh - as others have noted - this is suspiciously like the Eneloop XX AA.
NLee the Engineer a prolific Amazon battery and charger reviewer in his review suggests the same thing.
The AAA Ion Core Pre-Charged is rated at 800mAh - so these cannot be the Eneloop XX AAA -
again as others have suggested, as well as NLee the Engineer in the same Amazon review -
these may be 2nd Generation Eneloop AAA.
I have 6 of the AA and 2 of the AAA Ion Core Pre-Charged.
4 of the AA were bought earlier and are already in service - but I did do an initial out of the pack discharge at 500mA (as close to 0.2C as my Maha/PowerEx C9000 would allow)
Allowing at least 1 hour rest I then charged these up using 1200mA (0.5C) the readings when the charger said "Done" (I do realize this is not the capacity - but a mere indicator)
# - Discharge - Charge
1 - 977mAh - 2358mAh
2 - 992mAh - 2368mAh
3 - 982mAh - 2374mAh
4 - 971mAh - 2259mAh
I acquired 2 more AA and 2 AAA this time I did the initial discharge out of the pack, rest - charged -
then ran a Refresh & Analyze cycle using
AA 1200mA charge and 500mA discharge -
AAA 400mA charge and 200mA discharge
Size - # - Discharge - Charge - Capacity
AA - 5 - 999mAh - 2377mAh - 2425mAh
AA - 6 - 1079mAh - 2429mAh - 2430mAh
AAA - 1 - 519mAh - 668mAh - 794mAh
AAA - 2 - 520mAh - 658mAh - 791mAh
Pics:
both are marked as made in Japan
rounded squarish buttons with crinkled chrome similar to Eneloops.
I think the general consensus is right that the AA are probably Eneloop XX clones
and the AAA are probably 2nd generation Eneloops.
This would make the AA Ion Core Pre-Charged very good value, as they can be found for about $10 per 4 pack.
Pics:
