StuGatz
- Joined
- Feb 20, 2004
- Messages
- 576
With some recent chat about the new Eneloop XX batteries I went to a local retailer.
No XX to be found but there were some of the tried and trusted Duracell AAA & AA rechargables and in that I have used those as well as the Eneloops in the past, decided to pick some up because I was already there... :shrug:
Now for the devil in some details:
I noticed that there were two types available; white topped 800mAh and black topped 1000mAh.
Now I recall reading sometime in the past that the white topped Duracells were manufactured in Japan whereas the black topped Duracells were manufactured in China with some reference to the black topped batteries being in some way inferior to the white topped batteries.
Closer inspection of the packaging revealed that both the white topped 800mAh and black topped 1000mAh have "made in Japan" on the battery bodies. So either the prior country of origin info was incorrect or I in some way mis-read the post.
The white topped 8oomAh allege on the packaging that holds a charge "5X longer" than the 1000mAh batteries.
A search for the previous posts about Chinese (or at least black topped) manufactured Duracells have proven fruitless and now I am at something of a quandary about the difference in the mAh between the two types.
As I interpret it, the lower mAh number allows for a longer storage time and the higher mAh number allows for more active use such as more flashes with a camera or longer active run time in a flashlight?
I've further noticed that the Eneloops have an apparent 2000mAh / minimum 1900mAh rating and that some older Sony NI-MH rechargables have a 2100mAh...
