cernobila
Well finally got two of these cells to try out in my 2xC Prince.
http://www.dealextreme.com/details.dx/sku.26799
Charged them on my Pila IBC charger, they measured 4.14 and 4.16. Was impatient and did not top them up any higher. They fit the same as the AW black C cells.......started with the WA1111 rated at about 3.8A.......when cold, fires up on the second push on the button, when warm, turns on with first push.
Now, when used with the WA1160, (4.3A ?) it took about three pushes on the button before turning on, again when warm came on with first push.....After playing around focusing the 1160 and turning it on/off, the bulb gave up, (one side of the element melted) lucky that I have another three.
I don't have three of these cells so I could not test the WA1185, (3.4A) perhaps with a bit of luck, this one may start up on the first push on the switch.
In the meantime, I am quite happy with these cells in combination with the WA1111 bulb in the Prince and will continue using them in this light.
Perhaps somebody with the equipment and know how could test these and compare them to other C cells.
