znomit
Got my triple R2 cutter kit up and running.
Last winter I made a couple of taskled driven lights, dual Q5 for the road and quad Q2 for the trails.
A new bike and a focus on longer distances meant I needed to build a new light head and I wanted to get away from batteries so I could run 400 lumens all night.
Luckily the lads at the LBS had a shimano 3n71 hub dyno wheel just waiting for me.
Martin has published a bunch of dynamo circuits for extracting a good amount of power from a dyno.
Cutter Electronics had just come out with the triple cree R2 and narrow optic which seemed perfect for the road.
From this I should get the same output as my old dual Q5 setup, the dyno outputs only 500mA.
The light head was built from the same aluminium section as my MTB light but a lot shorter. Its about 5x4.5x2cm.
The disk in there is a 8x25 filter from ledsupply. It will spread things out to give a little peripheral light, good for some of the fast downhills around here, I hope. Also should make me very visible to the cagers.
See what it does to the beamshot:
The light end were sealed with yellow epoxy(just add some food colouring into the mix) to give bright sidelighting. Combined with my white bar tape this gives the cockpit a warm glow.
For mounting I'm a big fan of keeping the bars free, so mounting over the brake calliper seemed like a good idea. Made a swoopy bracket for this.
From last years riding experience I knew I wanted around 200lumens for normal riding and as much as possible for downhills. The 3 R2s at 500mA should deliver around 400 lumens. Martin has a combination voltage doubler/rectifier circuit which halves the power when required. I went with his circuit 10, crammed into a small box that hides under the handlebar stem. Bottom switch selects high/low and I added a on/off switch at the side. Liberal amounts of silicon slathered everywhere for waterproofing. The electronics are pretty simple, 3 capacitors, two switches, 4 diodes and a resistor. I will always run with a backup light so a standlight wasn't needed.
The end result is quite tidy. Note beamshots are hard using the dyno, this one is upside down on the table, note one led has a wide spread.
Total weight of the light head, wires and control box is 175gms. The shimano 3n71 hub is 700gms. My old 12AA battery pack alone was around 400gms so I think the weight isn't significant.
The hub drag is 2w with the light off and should be around 6/10w low/high. An extra 10w has got to help the training! The power requirements go up with more LEDs, the triple seemed like a good balance of light and power.
I got a bloke to mill the head unit but it could have been done with hand tools, just not quite as tidy.
Total cost probably a bit over 100NZ$ (this is similar to 12AA NiMH and charger!) plus the wheel.
