Through the kind courtesy of 4sevens I have on loan this EagleTac P10A2 - 2x AA flashlight based on the Cree Q5 with forward/tactical clicky and two light levels obtained by tightening/losening the head.
Size -
The EagleTac P10A2 is noticably bigger than the other popular 2AA lights
Head -
its head is bigger/wider too - which could result in more efficient throw or better beam shape.
This EagleTac P10A2 is rated at 220 lumens at the LED - this is brighter than most other Q5 based 2x AA (or 1x CR123) lights.
vs. Fenix L2D-Q5 both on max and NiMH -
side-by-side one can see that the EagleTac P10A2 is perceptibly brighter than the Fenix L2D-Q5 rated at 180 lumens.
vs. Fenix LD20 both on max and NiMH -
The Fenix LD20 is an updated L2D-Q5 and is more or less similar - rated at the same 180 lumens - it is still perceptible that the EagleTac is brighter.
How about a flashlight that is closer in (rated) brightness level?
vs. Fenix PD30 Turbo on 2x primary CR123
yep, about the same - considering the Fenix PD30 is a 2x lithium CR123 light rated at 220 lumens -
this is quite an achievement by EagleTac P10A2 for a 2AA light.
How about the "Lo" level? It is rated by EagleTac at 60 lumens (this is about the same as those once regarded as ultra bright 2x lithium CR123 xenon lights like the SureFire 6P or G2 and the Streamlight Scorpion)
vs. Fenix LD20 Medium NiMH
the EagleTac P10A2 "Lo" is actually brighter than the Medium on the Fenix LD20 (rated at 47 lumens).
All in all the EagleTac P10A2 is remarkably bright for a "mere" 2x AA light -
probably one of the brightest in its class for now.
The Lo mode is not exactly Low - as it is as bright as once regarded "ultra bright" 2x lithium CR123 xenon lights....
I guess it won't be too long before we have a flashlight with output bright enough to toast marshmallows?
Index to follow up parts -
Ad-hoc (look-see) comparison for throw with Fenix LD20 - Post #11
Standardized Stairway beamshot - Post #15
Size -
Head -
