I am searching for a new EDC, preferably LED. Right now I am seriously considering an EagleTacP20C2. I like the size of the light (I have been used to surefire e series size), the settings on it and am just trying to make sure I am making the right decision. I would prefer the ui of a rotating ring like fenix ta20 but that light just seems to bulky for pocket EDC. Any other suggestions to consider? Small pocket size (preferably less than 1" bezel and 5" length), good hotspot/throw, easy momentary switch, led are all important. Preferably <$120, pocket clip bezel down, hi/med/low settings, hi lumens.
As far as the P20C2, can you turn on the light in both turbo and general modes depending on the bezel position, or do you have to turn it on in one and move to the other? Also can someone describe the strobe, I can not find much information on it (Hz, random vs regular, pattern etc). I read: "activate strobe by double pressing the switch", would this be momentary press or full click? Also is the momentary switch easy and quick to activate repeatedly. I ask because I use manual strobing technique (similar to Strategos technique) for searching with. If it does activate the strobe setting I guess it wouldn't be that bad since it would just add to the strobing effect overall. Being able to easily strobe manually at high lumens with a good throw/hotspot is pretty important.
Thank you for the input.
