kramer5150
Can someone explain this?... I have 2 lights, Fenix MC10 and Malkoff M60 hosted by a 6P. In BCs 10.5" sphere the malkoff does 220 and the MC10 on HI does 120... Lumens OTF.
With some simple tailcap measurements the MC10 is 32 Lumens per Watt and the Malkoff is 42 Lumens per Watt.
Why is this? Why does the XRE-Q5 Malkoff generate almost 2x the OTF Lumens AND have better efficiency than the MC10. Shouldn't the mildly driven MC10 and its XPE-Q5 dominate the ancient XRE-Q5 from an efficiency standpoint?
On a similar note my SF-E2L uses an XRE and emits 110 in the sphere of truth. It hums along at 79 Lumens/Watt. Why would the E2L-XRE smoke the XPE on a lumens/Watt basis... when the 2 emitters are driven to near-identical output levels?
The other thing I find puzzling is that the E2L runs ICE cold at 110Lumens, it generates no heat. The MC10 at 120 Lumens generates considerably more heat. Why is that? Shouldn't the temperatures be nearly identical at very similar output levels?
Is Lumens / Watt not a true measurement of efficiency?
:thinking:.. very puzzled.:confused:
