funkychateau
OK, I just read through the "why are eneloops special" thread, and I'm thinking about trying a set for my digital camera, which uses 4 AAs. Currently, I keep two sets of NiMH in the case and one in the camera, and rotate/top off every few weeks to keep them fresh. The camera kit stays behind the seat of my truck, always ready.
If the eneloops are a good choice that reduce the periodic maintenance, then I'll be sold. But I'm wondering:
1. Are the eneloops close enough in charge-cycle requirements that I can continue to use my current collection of NiCd/NiMH chargers? In particular, are there different limits to current for "quick charging", and can the eneloops handle a constant 0.1-C trickle charge for several hours without damage?
2. Do the eneloops have the same low-series-R characteristics and capability to supply heavy currents without sacrificing significant capacity? In other words, if I use an AA eneloop in an application such as a single-AA flashlight that draws an amp or more, will the terminal voltage stay "up" as well as my NiMH cells in this high-discharge application?
thanks!
thanks!
