schamberlin
- Joined
- Nov 1, 2009
- Messages
- 5
I've read many happy reviews of Eneloop low-self-discharge batteries here and elsewhere, but do they really make economic sense? It seems to me they're squeezed between traditional (higher-capacity and cheaper) NiMH on one end, and single-use alkalines on the other, with a fairly narrow range where they make sense economically. Here's my analysis of the best battery for a given replacement frequency:
This analysis depends greatly on the predicted lifetime of the Eneloop battery. And I mean lifetime in years, not charge cycles. How long do you expect to keep using that new Eneloop? 5 years? It seems pretty likely to me that by 5 years, either the cell will no longer be performing well, or you'll have replaced it anyway with some newer technology. Use a different number if you want, but I think 5 years is probably on the high-end of what you could expect.
The best price I've found on AA Eneloops (including tax and shipping) is $3 per cell. Compare that to about $0.40 per cell for AA Duracell alkalines bought in bulk. In a five-year period, you'd have to replace those alkalines 7.5 times before you'd come out ahead by buying an Eneloop instead. That works out to replacing them every 8 months. When you use alkalines, do you really replace the batteries in your clocks, remotes, emergency flashlights, etc every 8 months? No.
On the other end, for things that get heavy use where you replace the batteries frequently (RC models, cameras, etc), you're probably better off with traditional NiMH batteries. If you're replacing/recharging batteries every 2 months or less, then there's not really enough time for the advantage of low self-discharge to pay off. Traditional NiMH will save you money, and give you higher capacities in this case.
Put it all together, and you get the three categories above, based on battery replacement frequency. That's a pretty narrow window for the Eneloop to hit. What's more, all the gadgets I have around the house fall into either the under-2 or over-8 month category, except maybe Wiimotes.
Have I overlooked something obvious? Is my battery usage atypical? LSD is certainly a nice feature, but just doesn't seem worth the trade-offs in most circumstances.
- 2 months or less: standard NiMH
- 3 to 7 months: Eneloop (or other low-self discharge) NiMH
- 8+ months: single-use alkaline
