What is the advantage of LI-Ion over LSD NiMh batteries?
I just started looking into Li Ion batteries about a year ago, although I've owned devices with Li Ion battery packs. But then I started looking into Li Ion single cells, and reading up on the do's and dont's regarding Li Ion batteries. But for some reason the OP question didnt dawn on me til today. I'd always just assumed that Li Ion technology was somehow better than NiMh, because since Li Ion batteries come with more (apparent)risk than NiMh batteries come with, there must be an advantage that makes the trade off worth it, right? I dont see the warnings linked to NiMh batteries that I see with Li Ion batteries. Maybe it's overstated just for absolute safety's sake, but there certainly are available stories about catastrophic failures of some sort with Li Ion batts. Many of them are sold with protective PCB's, etc attached to them, so there must be a reason for that. Nonetheless, I own a bunch of them and have not had any issues.
The said benefit of Li Ion is improved capacity. So I assumed(again) that with Li Ion batts, you would have higher capacity, longer battery life, as well as other electrical current related advantages, which would also justify the substantially increased cost of Li Ion batts.
But when I look at the capacity ratings of Li Ion batts vs. similar sized NiMh batteries, they are either almost identical, or in some cases, the NiMh batts have more capacity. That seems to contradict my assumptions....... For instance, LSD NiMh AA's have capacity of 2000-2100mah, vs. 14500 LiIon(the same size as AA) are only 750-900mah. The Li Ion 14500's have higher voltage, and I dont fully understand how that effects capacity though. **Does a higher voltage battery effect the capacity, so that capacity will always be lower than in a similar sized, lower voltage battery like a 1.2v NiMh AA?
Then, look at 18650's. The new, highest capacity model has 3400mah capacity. Compare that to a 8,000-12,000mah NiMh D battery. If you were to measure the actual internal physical size of 18650 vs. D batteries, the D isnt that much larger, so why does the Li Ion 18650 only have 1/3 - nearly 1/4 the capacity?
Aside from the NiMh comparison, there's the Lithium battery comparison that seems to reflect the same results. CR123's come in 1,400-1,550mah, whereas the same size RCR123 Li Ion battery comes in at around 750-850mah. So, once again, reduced capacity, but this time the voltage is similar. Even the 3v RCR123 has about 1/2 the capacity of a 3v CR123. Why?
So, why are Li Ion batteries of the same physical size as NiMh and Lithium batteries have less capacity? Wasnt that supposed to be one of the main advantages of Li Ion technology, more capacity? What
IS the advantage of Li Ion technology that makes the increased potential danger and increased cost justifiable? Is it that Li Ion technology gives us higher voltage in batteries of the same physical size as NiMh? It seems that the new NiMh batteries will last about as long as Li Ion bats will, so why not just go with that technology, or are they not capable of producing 3.6-4.2v in smaller sizes, like CR123 or AA size?
Because I dont have a 100% grasp on electrical theory, I dont know how stupid these question are, but it has me confused at this point..
