kosPap
hi all!
I will ask you to guesstimate on this.
I am about to change the batts on a 12V powertool which uses 1300mAh batteries 18650.
I opened up the pack, but the batteries do not mention a specific type/code, only tha maker, Puly, which makes power tool and not specifically batteries.
So there is no way to find the battery code an specs.
Goal is to determine the maximum amp draw of the replacement batteries, in order not to sacrifice power for capacity.
So what can the amp draw of industrial 18650 1300mAh batteries be?
