groutboy_1
Over the weekend I found a new Brinkmann 3 watt, 3 aaa , aluminum-tactical style flashlight. the body is gloss black, smooth handle surface, with alloy knurling spacer at the narrow bezel assemblie. it has a silent clickie, with a small, foward -facing, pocket clip that slides over the the switch. the clip of coarse can be removed. the light cost 24.99., and is about the same size as
the lx-styled 3 watt, but slightly thinner. it's got a little more heft. the output
is similar to the lx-luxeon...though, the unit that i purchased has a slight defect... the reflector base is bored-out a little to big near the emitter, and is misaligned by a hair....I can't get the bezel off, it's on pretty tight...I tested the light in my backyard at night, along with the lx-version...even with the defect,it brightly lit up a garage at about 30 yds. it producted a broad-beam at that range, giving the impression of a longer ranged 5 watt light...
