MacTech
Ever since i've owned it, my A2 has had a very faint, almost unnoticeable flicker in the periphery of the incan spillbeam, right near the edge
I've performed a few experiments to narrow down the cause of the flicker....
the batteries aren't an issue, i've tried cells anywhere from 100% to 40% charge, no difference, i've tried pulling the LED ring and running just the incan to identify what's flickering, it's the incan, it happens on two different bulbs, the stock bulb and a replacement
The hotspot and main spillbeam show no signs of flicker, very solid, it's just the very outermost ring that shows the flicker, it's also random, sometimes it shows, sometimes not, it was less apparent with the replacement bulb
it's only visible when WWH'ing or WCH'ing, unnoticeable in normal use, just wondering if this is normal
strangely enough, the stock bulb has a lot of artifacts, when i tried my replacement bulb, it was almost totally artifact-free, very bizzare
i know that the LVR in the A2 uses PWM, so i'd assume the flicker in the periphery is normal, correct?
